RS232 --> Bluetooth. What do you think ?
(Runs on MS2 and Microsquirt)
PARUS
Post by PARUS »
racingmini_mtl
Re: RS232 --> Bluetooth. What do you think ?
Post by racingmini_mtl »
Two things: it needs a 3.3V supply (and interface, I assume) and it's only rated at -5C to 45C operating temperature.
hassmaschine
Post by hassmaschine »
this one plugs directly into the MS serial port, and simply "works":
http://www.sparkfun.com/products/8495
WestfieldMX5
Post by WestfieldMX5 »
as does this one.
Peter Florance
Post by Peter Florance »
f_devocht wrote:as does this one.
Looks nice; what kind of range can you get?
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
WestfieldMX5
In house I can tune the car from inside the next room (car in the garage) with door closed in between. Outside, I haven't tested it yet.
piledriver
Post by piledriver »
Promo at newark, clearing out stock on those LM058s
$22
http://www.newark.com/jsp/search/produc ... B100000001
WestfieldMX5
That's very cheap! I'm using it for 2 years without any problems.
I also have a Wifi - serial adapter (Roving networks RN-134), but haven't had the chance to test it yet. Maybe the coming weekend.
Peter Florance
piledriver wrote:Promo at newark, clearing out stock on those LM058s
$22
thanks
Snagged it!
Peter Florance
PF Tuning
Breastfed
Post by Breastfed »
I also Hoovered one up ... been looking at BT devices for a while.
Only one is needed correct ??
Thanks for the tip
Breastfed
piledriver
Breastfed wrote:I also Hoovered one up ... been looking at BT devices for a while.
Thanks for the tip
Breastfed
You should be able to pair a std BT dongle on the other end, as long as your OS supports BT serial comms.
(In the amusement park of my mind I recall reading some setup instructions)
I bought 2 at that price, but hope to just put them on my 2 MS setups.
piledriver
EDIT--- Oh well, looks like Newark never had them to begin with, must have been an error in their system.
They offered me another part# for $88 ea, I had to politely say "shove it".
Breastfed
Post by Breastfed »
Don't think I'll we worrying to much ... was all good at the time of the order ... and today it was rejected out of stock
Breastfed
Peter Florance
f_devocht wrote:That's very cheap! I'm using it for 2 years without any problems.
Got mine. Did you power through the DB9?
Peter Florance
PF Tuning
WestfieldMX5
The LM058? Yes, I powered it through the DB9. I didn't yet test the wireless adapter, plan is to install it inside the case with an external antenna although this might be a problem for firmware updates as I always do those with a serial cable. Don't think 2 devices may be attached at the same time.
Breastfed
Post by Breastfed »
has anyone used the LM048 ? got one on the way
Breastfed
krisr
Post by krisr »
I've got an LM048 on the way also. Did yours arrive and did you have any luck?
Looking at both datasheets for the 048 and 058, they both look similar except for the actual size of the units. The 048 should work great in my car as i've not got much room where i've mounted the computer under the dash.
Sydney, Australia
1971 Holden Monaro HQ
Peter Florance
hmm my LM058 did not come with antenna
Any suggestions?
Peter Florance
PF Tuning
piledriver
What's it got for a connector?
Same band as wifi... Should be able to scarf an old wifi antenna if it uses SMA connector.
Peter Florance
piledriver wrote:What's it got for a connector?
Perfect! Thanks, I hadn't thought of that
Peter Florance
PF Tuning
