Blown Chip & Elusive Serial Monitor BDM File
(Runs on MS2 and Microsquirt)
Re: Blown Chip & Elusive Serial Monitor BDM File
Postby racingmini_mtl » Mon Mar 07, 2016 11:54 am
kim_gulle wrote:Sooo... do i have the correct data?
If this was addressed at me, I don't know and I'm not going to check. It would be time consuming to do so and this thread is pushing the boundaries of what this forum should be used for.
Postby slow_hemi6 » Mon Mar 07, 2016 6:33 pm
kim_gulle wrote:
racingmini_mtl wrote:
slow_hemi6 wrote:... and I definitely have data from f800 to ffff...
Which is another proof that you did not just load the B&G code s19 file and that you are not using normally a chip without a serial monitor.
This is not meant as a personal attack (you may simply have forgotten what you actually did to get back to a working setup) but I want to dispel once and for all this idea that you can get back to a working MS2/Extra setup simply by loading the B&G s19 file on a blank CPU with a BDM.
kim_gulle you would have to try it and see. All I can say is it is a bit different to what I saw on mine. Mine is definitely a older board.
Cheers Luke
slow_hemi6
Postby kim_gulle » Wed Mar 09, 2016 1:10 am
Yeah, i'll try it then. I'm guessing it should be flashed into the f800-ffff range? Or if using this file, i should just flash it directly into the beginning of the memory so that the actual data will be located at f800-ffff?
kim_gulle
Postby slow_hemi6 » Wed Mar 09, 2016 6:08 am
That is the point of the S record it has the address and the data.
Hang on, I just thought of something, the S123 record has the address, 32bytes and the checksum. I was looking at addressed 16 byte data and no checksum.
Yep your data and mine are the same, just the formatting was making me see it as different.
You may need this as your last record.
Code: Select all
S903F80004
Cheers Luke
slow_hemi6
Postby Mclain » Fri Apr 01, 2016 12:02 am
Hi There,
Found this topic on my road to getting my ms2 up and running.
I have the MS V3.0 with the commen problem, i blew the CPU myself.
This was 4 years ago. I eventually bought a new MS and now i want to use this board to work with my Injector tester.
So i took of the MCU and installed a new one(hot air).
I bought a USBDM freescale programmer and i am able to Identify the chip and upload the monitor file.
But after that i stumble uppon trouble.
After i uploaded the monitor, i try to install the firmware. This is what it will say:
Serial device:
Enter a comm port number (default 1): 13
Trying: COM13 ..#Opening comm port COM13
(\\.\COM13)
TX: 51
Waiting...
Waiting...
Waiting...
Sent Q and got 0 bytes back.
TX: 0d
e0 08 3e .. .. .. .. .. .. .. .. .. .. .. .. .. ..>
(3 bytes)
Sent 0d and got 3 bytes back Monitor found
#Closing comm port
Do you want to use COM13 (y/n default = y)
After that it will send the bootstrap. But for every TX, i get a RX e0 08 3e in return.
So it is clear that its not really communicating.
Any idea's on this issue?
Mclain
Postby piledriver » Fri May 27, 2016 6:07 pm
I wonder if when you blew your CPU the rs232 chips got taken out as well.
IIRC someone said the CAN chipfrequentily dies as well.
The basic comms troubleshooting in the manual is a good place to start.
piledriver
Postby Amin » Sun Jan 14, 2018 1:57 am
Hi dear friends
I have ms2
I soldering a new chip mc9s12c64 in my ecu
Can i flash this mcu with xprog (programmer) or no ????
And please send flash file to write ?
Or send link to download file???
Amin
Previous
Users browsing this forum: MaroonMonsterLS1 and 4 guests
