MS2 development/coding for dummies
(Runs on MS2 and Microsquirt)
Re: MS2 development/coding for dummies
Postby sunfield » Fri Aug 11, 2017 11:13 pm
sunfield wrote:
jsmcortina wrote:See the third post here: http://www.msextra.com/forums/viewtopic.php?f=91&t=43601#p308151
The upload went well. The tar created the directory d:/usr/.... In the usr/bin the are a lot of variations of m68hc11-elf-....... But the file I expected m68hc11-elf-gcc has the extention .exe and there is no one named without extention. What am I doing wrong?
Verstuurd vanaf mijn Nexus 10 met Tapatalk
Who can help me without the following "fout" = error 127
sunfield
Postby racingmini_mtl » Fri Aug 11, 2017 11:43 pm
I think there are issues with cygwin64. You need to use the 32-bit version. I know that's what I'm using and it works. And there are posts from last year that say the same thing.
racingmini_mtl
Postby sunfield » Sat Aug 12, 2017 1:18 pm
racingmini_mtl wrote:I think there are issues with cygwin64. You need to use the 32-bit version. I know that's what I'm using and it works. And there are posts from last year that say the same thing.
@jean, 32 bit version is working without problemen. Thanks
sunfield
Postby sunfield » Sat Sep 09, 2017 6:44 am
I am using table switching Patrol and LPG. The are some tricks to connect the thermo sensor to the ground for LPG by hardware. Who can help me to do this by software. I need some support where to change and which signals
Verstuurd vanaf mijn S30 met Tapatalk
sunfield
Postby jsdevel » Fri Sep 15, 2017 9:49 pm
http://www.msextra.com/tools/ is great. The version of gcc is pretty out of date. Has anyone tried using the latest version of gcc? I like to keep my system managed by dnf as much as possible which is why I ask.
jsdevel
Postby jsmcortina » Sun Sep 17, 2017 2:16 am
This is the latest version of gcc for s12.
Postby jsdevel » Tue Sep 19, 2017 12:09 am
Got it. Thanks James!
jsdevel
Postby jsdevel » Sat Oct 21, 2017 3:34 pm
Actually, I realized that I could probably bundle those tools up into a docker container. Then I could run a simple docker command. I'll post back once I have that working.
jsdevel
Postby jsdevel » Sat Oct 21, 2017 5:44 pm
I was able to create a .s19 from the ms2extra source with docker!
Here's the Dockerfile I used:
FROM fedora:26
RUN dnf install -y wget
RUN wget -q -O freescale-tools.tgz http://www.msextra.com/tools/s12buildto ... -24.tar.gz
RUN tar --strip-components=1 -zxf freescale-tools.tgz
RUN tar -zxf tools.tar.gz
RUN dnf install -y make which
ENV PATH="/usr/bin:${PATH}"
RUN dnf install -y glibc.i686
RUN dnf install -y zlib.i686
VOLUME ["/host"]
WORKDIR /host
In the directory I had my Dockerfile in I did this:
docker build -t freescale-tools .
After changing BINDIR to /usr/bin/ in the Makefile, I ran the following commands in my ms2extra directory:
docker run --privileged -v $PWD:/host freescale-tools make
docker run --privileged -v $PWD:/host freescale-tools chmod -R `id -u`:`id -u` .
And voila! megasquirt2.s19 was in my current directory!
I like this approach as I don't have to muck with / on my system.
jsdevel
Postby jsdevel » Sat Oct 21, 2017 5:45 pm
I'll also add that I loaded the .s19 file to my MS2 and it worked flawlessly.
James, would it be possible to include that Dockerfile in with the sources? Or would it violate the license if I published that Dockerfile as an image on dockerhub? It would be cool if `msextra-tools` were up on the hub.
jsdevel
Postby jsmcortina » Sun Oct 29, 2017 3:41 am
I'm not sure I understand the purpose of this 'docker' ?
The MS2/Extra build is fairly simple driven by a Makefile. If you have a different tools path, you can edit the Makefile and set your paths in the PROGPREF line.
Postby jsdevel » Sun Oct 29, 2017 8:30 pm
Yea, the Makefile is indeed pretty straight forward. I like using docker containers because I can avoid installing tools in global paths. Docker commands are run in a container, and containers are like light weight VMs.
jsdevel
Postby jsdevel » Sat Nov 04, 2017 4:48 am
Just stumbled upon this site and thought I'd share. Lots of relevant info: http://www.seattlerobotics.org/encoder/200109/encoder.htm
jsdevel
Previous
