[FW MOD] ms2extra 3.2.1 gslender v2.2c
(Runs on MS2 and Microsquirt)
gslender
Post by gslender »
MOD EDIT: Note that this firmware is obsolete. Please use the current release firmware from the Downloads page above.
G'day...
This modified firmware is based on the released MS2/Extra 3.2.1, and adds several enhancements designed to improve idle stability during load events, such as AC and other engine loads. See post http://www.msextra.com/forums/viewtopic ... 91&t=43545 for the prior release/s.
This v2.2c update is a release to the mods I've previously added and includes the following changes:
  • Added Idle State logging (to assist with idle tuning).
  • Added Dashpot Decay (MS3 version).
  • Fix for update of IVT with immediate effect (avoiding burn burp).
Docs >>
gslender.mod.application_notes.pdf
Firmware >>
ms2extra_3.2.1_gslender_v2.2c.zip
Source >>
ms2extra_3.2.1_gslender_v2.2c_source.zip
Enjoy :yeah!:
G
Mazda MX5 + MS3 Pro
BenGTT
Re: [FW MOD] ms2extra 3.2.1 gslender v2.2c
Post by BenGTT »
Thank you G.
Will try this fw for the first time on my test car next week.
Ben
gslender
Post by gslender »
No probs... Will be keen to hear how you get on ;)
G
Mazda MX5 + MS3 Pro
msegt
Post by msegt »
sure and i just put 2.2b on yesterday too, i guess i know what im doing today now.....lol....figured as much.... either way , i had no issues with the other one so ill load this one up shortly too...keep up with the good work tho, i love all the new features you keep backporting over. i was gonna ask when c was coming out before i loaded that yesterday too... oh well its easy enough
95 escort gt BPT - MS2E/ms2extra pre3.3alpha5 gslender v2.8 - E85 - 256/250 on mustang dyno at 10psi, now tuning for gtr turbo
HidRo
Post by HidRo »
Maybe just a noobish question, but here it goes:
I tried to check some differences between the 3.2.1 and your msq's, and I saw some odd numbers on the tps filtering or something.
What would I have to do to switch from the 3.2.1 to your's? What changes are needed and mandatory?
Thanks!
Gonçalo
gslender
Post by gslender »
No mandatory changes. You should be able to upgrade without enabling anything (I think).
The item I'd encourage you look at would be Adaptive Idle Advance.
Also, read the docs as most stuff is in there re changes and what is needed to enable the features.
G
Mazda MX5 + MS3 Pro
HidRo
Post by HidRo »
I don't use any kind of idle option (raw as it get :lol: )
No sure the idle adaptive stuff would work good with my setup. If if does, it is really good!!
As far as the docs go, I guess I've been reading, but not sure I found what needs to be enabled or not. :P
Thanks!
gslender
Post by gslender »
HidRo wrote:I don't use any kind of idle option (raw as it get :lol: )
The "idle adaptive stuff" might work for you - I assume the car does idle somehow, so you only need to enable a "Closed loop idle target rpm" curve (so you'll need to enable PWM Closed-loop even though you don't have a valve) and then create a curve that is applicable (could be a flat idle for all CLT temps).
Then setup Idle Advance and you should see the spark adjust to keep idle dead bang on the idle rpm you want.
HidRo wrote: As far as the docs go, I guess I've been reading, but not sure I found what needs to be enabled or not. :P
Then the only other advice would be to enable Median Sliding Window with a value of 3 across the board and increase all the Lag factors to 90% or higher if you are happy with the filtering. You'll find Median Sliding Window will give you better noise removal and better response than a Lag factor of 50. Some folks (including me) have seen better engine response when under full song because the MAP/RPM bins are more smoothly tracking through the VE table and so you're getting a better and consistent response.
G
Mazda MX5 + MS3 Pro
pigga
Post by pigga »
Hi.
Just one question: If I enable the "new" filter, will the old signal filtering factors keep active anyhow?
Thomas
gslender
Post by gslender »
pigga wrote:Hi.
Thomas
I assume you mean the Lag factor stuff? If so, yes they are both applied the same time. I've explained how it works here... http://msextra.com/forums/viewtopic.php ... 40#p309355
G
Mazda MX5 + MS3 Pro
pigga
Post by pigga »
Hi G.
Thank you very much. I think that is the point I was missing.....
Thomas
HidRo
Post by HidRo »
Well, if that is correct, and even without a valve, I can set it up to "PWM Closed loop" and have it have a dead on idle, that would rock!
My idle is quite ok when warm (1000RPM) but a bit low when cold (600+/-).
I'll have to give it a go.
So basically, set it all to 90 lag, and the new smooth to 3. Sounds easy enough :D
Thanks!
G :P
ol boy
Post by ol boy »
What changes in the app notes from the last notes released? Do you change the content in the app notes or is the same as the beta and v2, v2.1... releases?
thanks Ryan
gslender
Post by gslender »
ol boy wrote:What changes in the app notes from the last notes released? Do you change the content in the app notes or is the same as the beta and v2, v2.1... releases?
thanks Ryan
Things have changed between the releases (as always outlined in the 1st post). The app notes are updated where the new feature requires documenting (as such the current 2.2c app note has been updated).
G
Mazda MX5 + MS3 Pro
HidRo
Post by HidRo »
I installed the firmware, and did another change to the wiring (needed as I was loosing volts when teh lights were turned on)
The car seems to run smoother (not sure the wiring change is the one to "blame") but feels good.
The Idle stuff, I tried to look at it, but there are tooo many parameters to enter, etc, so I have not changed a thing :D
I'll have to try to figure something out.
Other than that, looks good!
Greg G
Post by Greg G »
Just flashed it in today. Initial impression- very nice!
The sliding window applied to RPM seems to have a significant effect on the responsiveness of both AIA and the PID code! I just used the recommended value of 3, with lag factor set to 90. The data seems to be much more lively-- the difference is really striking! At the same time, no crazy values are coming out. Idle RPM is even more solid now- and I was already happy before this!
Something is still nagging me about the dashpot action with AC. It still seems not to apply dashpot when the AC is on. The dashpot decay seems to only apply with dashpot values of >7. But it looks really promising, have to get some more data on it. Love the logging of engine status and dashpot decay :D
Greg
1996 Mazda MX-5 1.6L NA6/ Mazdaspeed M45 SC/ BSP AW Intercooler/ Maruha F-cams/ 425cc RX-8 injectors/ DIYPNP
MS2/Extra test mule :)
gslender
Post by gslender »
Greg G wrote:Just flashed it in today. Initial impression- very nice!
There is a bug in the ms3 code that I've fixed... so should have something soon to correct that.
G
Mazda MX5 + MS3 Pro
HidRo
Post by HidRo »
After checking the logs, it seems that the PW and DutyCycle are steadier, and the AFR is steady as well.
I took some logs the day before going to your firmware, and some with your firmware, and things seem a bit more stable!
I'm enjoying what I'm seeing!
Next step, idle improvement, and I'm all ears to what I need to change (I'm basically out in the blue on this one...)
gslender
Post by gslender »
HidRo wrote:Next step, idle improvement, and I'm all ears to what I need to change (I'm basically out in the blue on this one...)
As mentioned above, you'll need to enable CL PWM to set a CLT rpm target - something to aim for when idling. Then enable the idle advance (adaptive) set for Adder, and then create a curve that goes advance when under rpm, and retard when above rpm. Read the docs for an example.
G
Mazda MX5 + MS3 Pro
muythaibxr
Post by muythaibxr »
G
What bug?
