MS2/extra alpha 3.3.0a (2012/02/05)
(Runs on MS2 and Microsquirt)
Postby muythaibxr » Sun Feb 05, 2012 6:09 pm
Changes since 3.2:
- Incorporated gslender's backports of ms3 idle features. Some are direct backports and some are re-implementations where necessary given ms2's limited resources
- Changed 100 to 100L to prevent EgoLimit multiplication overflow
- Make rotary trailing work with 36-2-2-2 wheel
The firmware can be found here:
http://www.msextra.com/doc/ms2extra/fil ... 120205.zip
muythaibxr
Re: MS2/extra alpha 3.3.0a (2012/02/05)
Postby Greg G » Sun Feb 05, 2012 7:09 pm
Thanks Ken! Was anything changed in the smoothing/filtering of the inputs (map,RPM,tps, etc)?
1996 Mazda MX-5 1.6L NA6/ Mazdaspeed M45 SC/ BSP AW Intercooler/ Maruha F-cams/ 425cc RX-8 injectors/ DIYPNP
MS2/Extra test mule :)
Greg G
Postby muythaibxr » Sun Feb 05, 2012 7:55 pm
That has not yet been backported from MS3. It will at some point be backported.
muythaibxr
Postby chango de naranjito » Mon Feb 06, 2012 7:21 pm
Hi,did the rotary mode un microsquirt mode is fixed in this alpha?
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
chango de naranjito
Postby muythaibxr » Mon Feb 06, 2012 10:46 pm
I have not been able to reproduce your issue.
muythaibxr
Postby chango de naranjito » Tue Feb 07, 2012 6:30 am
ok, I will rewire and try it with this alpha thanks Ken
chango de naranjito
Postby piledriver » Sun Feb 12, 2012 5:07 pm
Kudos!
6/1 wheel sequential, Bosch CIS air valve ONLY for start/warmup fast idle .
The new idle control ROCKS for me, as I only use timing control for active idle stabilization.
I used to use the transition from cold idle+table timing to idle control as an audio cue I was warmed up as it started hunting up/down when it hit setpoint. (was still +/- ~75 RPM, better when warmed up)
Now idle speed and recovery is smooth and rock steady.
All I had to do was turn it back on and set it to adaptive, and it works ~like a PID closed loop idle speed control, without having to jack with it. (have not had a chance to play with it properly)
I was planning on finally getting around to installing an idle air valve, but now I may use fidle for something else.
No issues noted, ~150 miles so far on this code.
piledriver
Postby chango de naranjito » Fri Feb 17, 2012 3:03 pm
muythaibxr wrote:I have not been able to reproduce your issue.
I tested again and the problem persists even if set it to 6 cylinder and 8 waste spark it do not fire I used a v2 microsquirt and a v3 as well... If you can get it to work please post the msq and the wiring setup , thanks!!
chango de naranjito
Postby jsmcortina » Fri Feb 17, 2012 3:16 pm
Post your MSQ.
I can supply, repair or upgrade Megasquirts in UK.
Postby chango de naranjito » Fri Feb 17, 2012 6:53 pm
Post your MSQ.
sorry forgot to post the msq...
13bpp.zip
(9.75 KiB) Downloaded 20 times
chango de naranjito
Postby jsmcortina » Sun Feb 19, 2012 7:52 am
Rotary isn't enabled in that MSQ??
Postby jsmcortina » Sun Feb 19, 2012 8:41 am
No fault found.
I've tested 6cyl w/s, 8cyl w/s and 4cyl with rotary enabled.
I did find a mistake in your MSQ though - you have spark output set to "normal" when it should be set to "inverted"
Postby chango de naranjito » Mon Feb 20, 2012 2:29 am
jsmcortina wrote:No fault found.
Oh,I did that to see if had any change but the only change was me burning the coils,please post the wiring you use maybe was me wiring it wrong, thanks!!
chango de naranjito
Postby jsmcortina » Mon Feb 20, 2012 4:29 am
My wiring was:
Microsquirt module -> LED on Jimstim.
Postby piledriver » Mon Feb 20, 2012 3:38 pm
Having the dwell set upside down will smoke non self-protecting coils, as will shorted tab> insulators>case on the drivers.
piledriver
Postby chango de naranjito » Tue Feb 21, 2012 6:20 am
jsmcortina wrote:My wiring was:
did you use pull ups? and the rpm input of the stim?
chango de naranjito
Postby jsmcortina » Tue Feb 21, 2012 6:24 am
The module spkC and spkD will need pullups to 5V yes.
Perhaps it would help if you posted a full description of what problems you are having. All I've gather so far is "it doesn't work" but I have no idea what test situation you are using, wiring or anything.
Postby chango de naranjito » Tue Feb 21, 2012 6:44 am
jsmcortina wrote:The module spkC and spkD will need pullups to 5V yes.
I will try again and post the full information and a video if I can, sorry for the lack of info
chango de naranjito
Postby tomeric914 » Thu Jun 07, 2012 8:45 am
piledriver wrote:The new idle control ROCKS for me.
I looked in the changelog but it must not be updated yet. What new idle control is in this version? Will it work for fuel only applications?
tomeric914
Postby piledriver » Thu Jun 07, 2012 5:47 pm
I'm currently using the ignition control, it twiddles the ignition timing for idle stability.
I'm using glsenders variant currently, can't recall if the idle timing mod was now in mainline.
piledriver
Next
