Ligerzero wrote:muythaibxr wrote:If EAE cuts fuel while MAP is on its way down the table then overrun fuel cut takes over as soon as you're there, the excess fuel burns off before the throttle is all the way closed and the RPMs drop quickly. I'm not sure it's as quick as completely cutting spark, but it does have the benefit of cutting the time for RPM to drop AND avoiding backfires.
I had already leaned my lower VE tables to the edge of driveability and it only had a small impact on RPM decel when changing gears quickly from a high load condition. I have played with the decel fuel enleanment but this feature is not triggered correctly to be reliably used and causes a loss in throttle response under various conditions. Regardless, complete ignition cut is necessary to maximize RPM deceleration. A properly tuned VE table and enrichment set will prevent most backfires to begin with.
Full ignition cut is done on OEM cars as well, although primarily on exotics (both with and without sequential gearboxes) which require high RPM deceleration rates. The difference is that their ECU’s have better enrichment control which eliminates the exhaust backfiring. Even still, there is nothing preventing a person from using this on a street car. As I mentioned previously, I experience no exhaust backfiring under normal driving conditions; you have to correctly tune the enrichments and VE table.
gslender wrote:dontz125 wrote:Is it possible to add a 'duration of cut' variable? (if there isn't one ... ?)
Would be simple and small in terms of code to do that.
dontz125 wrote:gslender wrote:dontz125 wrote:Is it possible to add a 'duration of cut' variable? (if there isn't one ... ?)
How hard would it be to add the option of varying the cut time according to a knob / pot, allowing the rider to tune this on the fly?
pigga wrote:By the way: Is there a chance to monitor the Status of PE0 for idleUp in the actual firmware? (Just to ensure the input circuit works as intended)
* fixed Median Sliding Window against rpm/tps/map/lambda (thanks Rob for point out my errors)
Hahns5.2 wrote:* fixed Median Sliding Window against rpm/tps/map/lambda (thanks Rob for point out my errors)
What was fixed? Does this code offer even better noise filtering over the 3.2.1 V2.2c?
gslender wrote:More to the point, the 3.3.0b alpha release has a MAP Averaging implementation, and this oversamples the sensor to provide nearly a noise free input with zero response lag.
pigga wrote:gslender wrote:More to the point, the 3.3.0b alpha release has a MAP Averaging implementation, and this oversamples the sensor to provide nearly a noise free input with zero response lag.
Hi G., are there plans to port this averaging map sampling strategy into your modified firmware?
pigga wrote:Will a sliding window algorithm smooth the output of the CL idle loop (and what would be the effect? Can I increase "P" for instance, then?).
And what´s behind this Idle Voltage Compensation? Will the PWM idle voltage compensation only be active if this option is "on"?
Again, thanks a lot for your Help ex ante!
Greg G wrote:The PID RPM window smoothing - Use values from 3-7. Or leave it off, working on a better solution
Idle Voltage Compensation - worked well in theory, but it's not producing the desired results. Leave it off for the moment, working on something hopefully better. ;)
