MS2/extra alpha 3.3.0b (2012/02/27)
(Runs on MS2 and Microsquirt)
Re: MS2/extra alpha 3.3.0b (2012/02/27)
Postby robs » Thu Mar 22, 2012 5:17 pm
He isn't using the standard code, but I wonder if the behaviour he's seeing might be caused by the standard code I highlighted yesterday. i.e. when the ISR accumulates the samples then falls through (wrongly, I'd say) to the sampling window code. The symptoms sound like when the sampling window is too narrow. Shouldn't be since he's using the sample average option. With the new flags, there are new combinations. I can't tell at a glance that all possibilities are covered and perhaps a few relics from an old config take the code down an unexpected path.
Have fun,
Rob.
robs
Postby gslender » Thu Mar 22, 2012 6:34 pm
robs wrote:He isn't using the standard code.
If he is using 2.4.4 then it may be the changes I made to ensure MAP is sampled when averaged and the engine isn't running.
The standard 3.3.0b didn't average sample when engine was stopped (as it relied on an ignition pulse to pull the sample out) and I changed a few things to allow it to work whilst not running. I don't believe issues exist, but will look at it tonight when I get home.
G
Mazda MX5 91 NA6 LE | M45 Mini SC | 4-2-1 Extractors & HI-Flow Exhaust | HSD HR Coilovers | MS2 DIYPNP Full Seq running ms2extra pre3.3alpha5 gslender v2.8 | Toyota COP | RX8 425cc Inj | W2A Intercooled
gslender
Postby gslender » Fri Mar 23, 2012 1:07 am
Trumpetrhapsody wrote:Looks like my MAP value hangs at the initial startup value... which would explain alot.
Now gurus, why would enabling map sample averaging mode cause this?
Any chance of trying the real 3.3.0b as I can't immediately see any reason why this would occur in the mod 2.4.4, as folks who've tried 2.4.4 haven't reported this issue (and I don't see it myself).
If the issue presents itself in 3.3.0b then the issue might be a type of config as generally again most folks dont' see any problems.
The only thought was that the non-averaging settings might still be in play (as Rob's pointed out) so I will look at that to see if it could possibly impact things.
G
gslender
Postby Trumpetrhapsody » Fri Mar 23, 2012 8:25 am
Sure, I'll load up the generic 3.3.0b at lunch and report back. Thanks guys!
L28ET I-6 Motor | MSII Extra v3.0 PCB | EDIS Coilpacks & Module | Boost Control | Knock-Sense
Trumpetrhapsody
Postby Trumpetrhapsody » Fri Mar 23, 2012 9:30 am
It's doing the same thing on the straight 3.3.0b code.I can switch back and forth and as soon as i go averaged the MAP value sticks.
Trumpetrhapsody
Postby muythaibxr » Fri Mar 23, 2012 12:14 pm
Trumpetrhapsody wrote:It's doing the same thing on the straight 3.3.0b code.I can switch back and forth and as soon as i go averaged the MAP value sticks.
Have you posted your msq? This is likely something specific to your configuration.
muythaibxr
Postby Trumpetrhapsody » Fri Mar 23, 2012 12:28 pm
I posted the MSQ I was using with the gslender mod near the end of the previous page, but if you want it I'll attach the one I was just using on the straight 3.3.0b.
330bTune.msq
(81.66 KiB) Downloaded 14 times
Trumpetrhapsody
Postby jsmcortina » Fri Mar 23, 2012 1:37 pm
I've repeated this on the bench.
I can supply, repair or upgrade Megasquirts in UK.
Postby jsmcortina » Fri Mar 23, 2012 1:57 pm
Fixed it ready for next release.
Postby gslender » Fri Mar 23, 2012 2:17 pm
jsmcortina wrote:Fixed it ready for next release.
So what was broken or wrong?
gslender
Postby Trumpetrhapsody » Sat Mar 24, 2012 7:26 pm
Ah excellent! Glad it was something simple. 20 minutes is quite the impressive turnaround ;)
Does "ready for next release" mean I have to wait for 3.3.0c, or have you re-uploaded 3.3.0b with the fix?
Thanks!
Trumpetrhapsody
Postby piledriver » Sat Mar 24, 2012 8:38 pm
Trumpetrhapsody wrote:.....
Thanks!
That's why I keep coming back, great service.
Try the veal!
piledriver
Postby AdamR » Sun Mar 25, 2012 9:28 pm
There was a thread a while back about cutting spark during overrun to make the engine decel faster between gears, but I can not find it at all. Does anyone remember the title?
AdamR
Postby BenGTT » Sun Mar 25, 2012 11:38 pm
AdamR wrote:There was a thread a while back about cutting spark during overrun to make the engine decel faster between gears, but I can not find it at all. Does anyone remember the title?
Hi, this ? viewtopic.php?f=91&t=43197
BenGTT
Postby gslender » Mon Mar 26, 2012 1:14 am
It is this release, or at least it should be. :P
G
gslender
Postby piledriver » Mon Mar 26, 2012 6:59 am
G
It is and works well.
Dropping my lag to 50 in addition to the averaging got rid of any ill effects of resonance at pq tq and pk hp for me, and it's running fabulous now. (after remapping everything, sometimes I wish there was an option to reverse the effect of VEAL i.e. change AFR target table if the VE table is ~perfect, might be useful post dyno)
piledriver
Postby pit_celica » Mon Mar 26, 2012 8:59 am
This feature exist. You need to set "Incorporate AFR target" to "include AFR target" in the General Settings. You need to specify the stochiometric AFR for your fuel. I'm not sure how it works exactly, but I know that is does just what you want to do.
Sam
pit_celica
Postby piledriver » Mon Mar 26, 2012 2:33 pm
pit_celica wrote:
....sometimes I wish there was an option to reverse the effect of VEAL i.e. change AFR target table if the VE table is ~perfect, might be useful post dyno)
Sam
Cool, I'll give it a shot, thank you!
piledriver
Postby andyducati » Wed Apr 04, 2012 6:38 am
Hi all,
I have just uploaded this new firmware to my MSII and every time i power up the MS i get a Settings Configuration error.
The reported setting error is "INVALID MAP SAMPLING ANGLES. NEEDS TO BE LESS THAN 180 DEG FOR 4CYL OR 90DEG FOR V8"
What does this mean and where is the setting to change this.
I am running a SBC 5.7 TPi with EDIS.
I have had this on the 3.2.1 firmware also.
Please help
Andy
2012-04-04_12.38.50.msq
(87.62 KiB) Downloaded 14 times
1991 Discovery. 5.7 SBC TPi, MS2extra, EDIS, LPG.
1985 Range Rover Landranger Kit. 4.6 Rover. To be MS'd for LPG.
1993 Ducati 888
1992 Ducati 900SS
andyducati
Postby nismoautoxr » Wed Apr 04, 2012 8:54 am
I loaded 3.3.0b on my car last night and it is working pretty well . I have not made any changes to enable any of the new features but I do notice my idle isnt quite as steady especially recovery on startup . Otherwise it is working just as good as 3.2.1. The engine stalled on me last night on the testdrive following a fairly long fuelcut overun decel down a hill which is a first time occurance . Not sure what tweaking I need to do to the MSQ to correct that. I havent toyed around with it yet.
Ricky-
1995 Nissan 240sx, LS1 v8 N/A 6speed trans , MS3&MS3X,29lb/hr inj.,230/232 @.050 on 114LSA cam, semi sequential fuel and sequential spark
nismoautoxr
PreviousNext
