Should PW be different between 1&3 and 2&4 ??
(Runs on MS2 and Microsquirt)
Postby gslender » Mon Apr 23, 2012 12:42 am
I've been playing with a JimStim and a spare DIYPNP board (microsquirt2) and noticed an odd behaviour with Seq Inj.
Initially, when first turning on, and you've got the JimStim set to steady RPM (1275) and steady MAT (29), CLT(91) and TPS (4) running same config/tune that would be running on the car (using a similar DIYPNP / Microsquirt2) all the PW are exactly the same.
If I play with the RPM up and down, eventually the PW1&3 become different then PW2&4.
For example, mine right now are 6.430ms (1&3) vs 5.931ms (2&4).... is that expected? Seems odd?
G
Mazda MX5 + MS3 Pro
gslender
Re: Should PW be different between 1&3 and 2&4 ??
Postby gslender » Mon Apr 23, 2012 1:49 am
Just tried it with 3.2.1 firmware and same behaviour?? :?
I'm seeing up to .5 ms difference between 1&3 and 2&4 !!
Why?
g
Mazda MX5 + MS3 Pro
gslender
Postby gslender » Mon Apr 23, 2012 2:05 am
Ahhhh... figured it out!
It is EGO control. For some odd reason, it mucks up the PW such that they are different between cycles... I've yet to wire in the O2 pot on the JimStim. Will do that and see if the AFR is bang on will it still do it... I hope not!
G
Mazda MX5 + MS3 Pro
gslender
Postby gslender » Mon Apr 23, 2012 2:15 am
Yup, with EGO control on it is almost impossible to get the PW back to stable again once it veers off AFR Target. I think the PID controller is to blame.
Mazda MX5 + MS3 Pro
gslender
Postby gslender » Mon Apr 23, 2012 2:18 am
OMG :o the ego control seems to be only applying to PW1 and (therefore PW3 for seq inj) in which case it isn't working on the PW2 (& PW4) side of things!!??
Mazda MX5 + MS3 Pro
gslender
Postby richyvrlimited » Mon Apr 23, 2012 2:20 am
gslender wrote:OMG :o the ego control seems to be only applying to PW1 and (therefore PW3 for seq inj) in which case it isn't working on the PW2 (& PW4) side of things!!??
Good catch!
2003 MX5. Coldside MP62
richyvrlimited
Postby gslender » Mon Apr 23, 2012 2:37 am
I know what is wrong in the code too.
In ms2_extra_ego.c in the ego_calc function it only updates outpc.egocor1 when for seq inj it needs egocor2 updated as well (or maybe the main function is wrong in how it applies egocor1 and egocor2 for sequential ?? (it would depend on what Ken or James was thinking when they did this).
Code: Select all
        outpc.egocor1 = egocor_100[0] / 100L;
        if (flash4.dual_tble_optn) {
            egocor_100[1] += ego2step;
            if (egocor_100[1] > (100000 + ltmp)) {
                egocor_100[1] = 100000 + ltmp;
            } else if (egocor_100[1] < (100000 - ltmp)) {
                egocor_100[1] = 100000 - ltmp;
            outpc.egocor2 = egocor_100[1] / 100L;
/// this code below needs to be added to fix it
        else outpc.egocor2 = outpc.egocor1;
Mazda MX5 + MS3 Pro
gslender
Postby gslender » Mon Apr 23, 2012 3:00 am
Just checked MS3 1.03 and found that it was fixed or at least sorted so the bug doesn't exist in that firmware!
Code: Select all
    outpc.egocor1 = outpc.egocor[0];
    if ((ram4.EgoOption & 0x03) && (ram4.egonum > 1)) {
        outpc.egocor2 = outpc.egocor[1];
    } else {
Mazda MX5 + MS3 Pro
gslender
Postby jsmcortina » Mon Apr 23, 2012 3:06 am
The MS3 implementation is quite different though.
Postby jsmcortina » Mon Apr 23, 2012 3:47 am
Please post an MSQ.
I just tried this on the bench and with the settings I'm using I don't see a problem? (All four PW follow each other.)
Postby gslender » Mon Apr 23, 2012 3:59 am
jsmcortina wrote:Please post an MSQ.
James, you can simply read the code and/or watch egocor1 and egocor2 in TS.... egocor2 never changes off 100% whilst egocor1 does... the bug is there!
I added the fix I described and it now works fine.
G
Mazda MX5 + MS3 Pro
gslender
Postby gslender » Mon Apr 23, 2012 4:01 am
just to show you... in ms2_extra_main.c
Code: Select all
            lsum1 = (lsum * ((outpc.egocor1 * lsum2) / local_div)/100);
            lsum1 = lsum1 * ((outpc.vecurr1 * (long)flash4.ReqFuel)/ 10000); // .01 usec
            if (((flash8.seq_inj & 0x03) == 3) && (seq_inj_ctrl & SEQ_HYBRID)) {
                lsum1 *= 2; // double the reqfuel do to the single pulse
            lsum2 = (lsum * ((outpc.egocor2 * lsum2) / local_div)/100);
            lsum2 = lsum2 * ((outpc.vecurr2 * (long)flash4.ReqFuel)/ 10000); // .01 usec
lsum2 only works on egocor2 !!
Mazda MX5 + MS3 Pro
gslender
Postby jsmcortina » Mon Apr 23, 2012 4:18 am
Yes, but normally egocorr2 = egocorr1
You do need to post an MSQ because only certain conditions highlight this.
I'm seeing it now - it happens if PID EGO, but not with "simple" which is how I tested.
Postby gslender » Mon Apr 23, 2012 4:23 am
jsmcortina wrote:Yes, but normally egocorr2 = egocorr1
Well, as long as you found it. :)
G
Mazda MX5 + MS3 Pro
gslender
Postby racingmini_mtl » Mon Apr 23, 2012 6:31 am
I agree that the code needs to be corrected as shown. It is obvious if you look at the simple algo code which does have the correct egocor2 else statement.
racingmini_mtl
Postby jsmcortina » Mon Apr 23, 2012 7:58 am
The just-released 3.2.2 aims to correct this bug.
Thanks to Grant for pointing it out.
Postby Peter Florance » Mon Apr 23, 2012 8:02 am
Plus then James has something to test.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Peter Florance
Postby ashford » Mon Apr 23, 2012 10:02 am
is this problem showing up when using single o2 sensor or dual?
ashford
Postby jsmcortina » Mon Apr 23, 2012 10:03 am
I observed it with a single sensor selected.
