I'm not sure what you are explaining here - can you be more specific about the correct names of the settings you've set and what is going on?Ricardo_Penteado wrote:1)- When the motor is in cut-off condition, strangely the Idle Closed Loop control is being triggered, even with the PulseWidth = 0 ( I imagine that there is no situation that would require this). My RPM cut-off trigger is 1600 RPM. Imagine that the motor is in cut-off condition and the RPM is in 2000. At this situation, the IAC is being closed to its minimum position - the code is trying to correct the RPM without success (of course ). If at this point I press the clutch, the motor dies (sorry, I don’t know if this is the correct English word). Analising the logs, I noticed that at exactly this point, the IAC is being opened to correct the RPM, but there is not enough time for that.
Again, not 100% sure I know what you are talking about - are you saying the PID lockout max decel load% isn't high enough? I can't see how in decel with AC it would be impacted? But please confirm if that is what you are talking about.Ricardo_Penteado wrote:2)- The motor load condition in Idle increases about 10~15 KPA when I turn on the AC. If I increase the Idle Closed Loop Load trigger condition by this same amount, the problem described above is solved, BUT then when the AC is turned off, then the load trigger is almost never reached and the closed loop algorythim is not triggered, locking the RPM in a higher situation (around 2000 RPM).
G
