Tacho jump and *bak* sound from intake after 3.3.2 beta2
Re: Tacho jump and *bak* sound from intake after 3.3.2 beta2
This is working fine...! it's PRE3.3 beta17
MSnS'n'4G15
OK. What is the last release that works and the next release that does not.slyrye wrote:This is working fine...! it's PRE3.3 beta17
I haven't check 3.2.5 release but 3.3.1a is a no no...! if you're referring to releases and not the betas thanks thanks James...!jsmcortina wrote:OK. What is the last release that works and the next release that does not.slyrye wrote:This is working fine...! it's PRE3.3 beta17
MSnS'n'4G15
You say beta17 works. How about beta18, beta19, rc1, rc2, rc3 ?
http://www.msextra.com/doc/ms2extra/files/beta/
http://www.msextra.com/doc/ms2extra/files/rc/
geez i have to try all of them? can we somehow do smart statistics here and so i can just try rc3jsmcortina wrote:You say beta17 works. How about beta18, beta19, rc1, rc2, rc3 ?
MSnS'n'4G15
Divide and conquer. Try halfway, then halfway before or after etc.
In this case, there aren't many release, so start with RC2.
If it works, then try later ones, if not try earlier.
alright will do, but I have to change back to stock CAS , I'll post some more logs soonjsmcortina wrote:Divide and conquer. Try halfway, then halfway before or after etc.
MSnS'n'4G15
James we are good to go!!! I reflashed my MS2 and now it's working superb...! let's move on to the next BETA...! but it was really strange...!
MSnS'n'4G15
Was this a firmware issue bug/ and if so did it affect anything beyond this specific spark/wheel mode?
Wes,
I've changed nothing.
James I'd like to report that there's a very dramatic power-loss on this firmware, I can't think of any but the "hiccup" behaviour we are experiencing on 4 vanes setup like 4G63T, if I can get myself or anybody a hold on to an oscilloscope I would like to capture in realtime the output pulses from ignition and fuel injection from MS2 so we can get a clear behaviour of what's really going on, what the composite logger fails to do so.
MSnS'n'4G15
Post in one topic.
The "scatter gun" approach does not help.
As mentioned before, without any data (i.e. datalogs) this report gives us no chance to investigate, let alone "fix" any apparent issue you are seeing.
In the beta5 topic, there was a clearer report of the behaviour and MSQs posted. This has led me to discover a bug in the AC idleup output code. That should be fixed and I'm about to post beta6.
