MS2/Extra pre-3.3.2 beta 3 released
(Runs on MS2 and Microsquirt)
Re: MS2/Extra pre-3.3.2 beta 3 released
Post by jsmcortina »
One topic please.
slyrye
Post by slyrye »
jsmcortina wrote:One topic please.
James you might also wanna check out A/C output pin when I choose D15 "sometimes" it's behaving like tacho output pulsing on and off... :o
MSnS'n'4G15
Yes, there was a bug there. Now fixed.
slyrye
Post by slyrye »
awesome....! :yeah!: :yeah!: :yeah!:
MSnS'n'4G15
slyrye
Post by slyrye »
James we are good to go!!! I reflashed my MS2 and now it's working superb...! let's move on to the next BETA...! :yeah!: :yeah!: :yeah!: but it was really strange...!
MSnS'n'4G15
wes kiser
Post by wes kiser »
When using microsquirt module there appears to be an .ini problem in the nitrous dialog. The ports I am allowed to select sound like MS3, not like microsquirt. I haven't checked to see if/how they tie back to actual function.
I just realized there is now a beta 4, would it be better to try that?
It looks like some MSPNP names slipped in there in error. I'll back them out.
Turbofreakdotcom
Post by Turbofreakdotcom »
Hi James,
I am running 3.3.0. and for the longest time (since 3.0.3 and previous) I've been fighting an issue with pulsewidth dropping about 50% under full throttle through the RPMs. It appeared to be MAP decel, but it was set to full TPS AE. Is it correct this version fixes this?
Main changes since pre-3.3.2 beta 2
Bug fixes:
Added range checking to flex frequency like MS3.
Restrict possible baud rates to reduce risk of no-comms. (Code from MS3)
Fix egov2 datalogging typo in ini.
Bugfix to normal-AE so MAP-decel cannot trigger if 100% TPS
triggerteeth range
Fix FLEX JS11 config error reversed sense.
Launch could leave fuel-cut on in error if TPS was quickly removed.
Updated 6/20/18:
87 Supra-3.0 1.5JZ-A340 trans
MS2 ECU
MS2 Trans controller
acab
Post by acab »
Turbofreakdotcom wrote:Hi James,
Bug fixes:
triggerteeth range
i think i have some problem here on 3.3.2
http://www.msextra.com/forums/viewtopic ... 01&t=54908
