TPS correction when on partial boost
Re: TPS correction when on partial boost
No that's not a good practice.. Plus the ego limits are not rpm dependent must be at least at 15% so that it corrects fuel when cruising and idling etc. So you cannot use it..
Miata NBFL 1.6 (EU), GT2560R, MS2Extra, Zeitronix.
Fiesta 1.25 Zetec-SE, N/A mods, MS3, AEM.
Okay, there goes that idea then
If the developers find that it is not needed then ok.. I may start reading the coding for dummies..
Have you tried what I suggested? Have you poured over the logs and verified it is not also somewhat dependent on RPMdot?
Of course it is somewhat rpm dependant. I haven't tried it yet as the car is apart now, I am building a forged engine at the moment and will try it as soon as i gets out of the shop.
Thanks again of course,
Nick
Nick
