Logic spark wiring
(Runs on MS2 and Microsquirt)
dontz125
Re: Logic spark wiring
Post by dontz125 »
It's in the manual.
savagerocco
Post by savagerocco »
I just downloaded the pdf and looked thru the Web manual and didn't see the diagrams in the ignition section. Am I missing something? I may just be hungry and tired but I didn't see it anywhere.
Brent Savage
life behind the zion curtain
90 audi RS2 20VTQ 6sp MS3, MSX COP and Sequential and now MAF
87 Scirocco 2.0 ABA 16v EIP tubular cast MSII COP
86 Audi 4K20VTQ MSII
90 Audi 90 sedan 3.6l DOHC V8TT (project car)
89 VW cabbie (bitch basket) 2.0 ABA Turbo MSII
savagerocco
Ok I found it in the base manual not the ms3x manual. I'm guessing the best way to go is not use the msx output and use the spark outs?
Brent Savage
dontz125
Post by dontz125 »
Section 5.3.1.3 Logic spark outputs - FET driver method, p. 76 for the description, schematic on the next.
Are you using a MS3 or MS2? Do you have the MS3X card?
savagerocco
Yes I have the ms3x been running it several years with pnp drivers. But I started with ms1 on this car and skipped Ms2. Tried the Ms2 but due to difference in trigger setup I didn't actually get running until ms3
Brent Savage
eMTea
Post by eMTea »
Hi!
This thread has several options for circuits for the PNP booster, but I can't keep up with you :P
Can anyone please refer to at schematics that works, so I can order the right transistors? I run MS3X and want to use the vag coils. Planning to bulid a small external box to put the drivers inside.
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
Post by jsmcortina »
eMTea wrote:Hi!
I have PCBs if you want to buy one.
mega_user
Post by mega_user »
Will the MS3X board be updated with the TC4427 elements ?
dontz125
Post by dontz125 »
mega_user wrote:Will the MS3X board be updated with the TC4427 elements ?
That's entirely up to B&G, the nice people who actually own the design, and sell the assembled cards to the various distributors. There are a number of "opportunities for improvement" that have been noted over the past few years, and it's due for a rev2.
mega_user
Post by mega_user »
Is it possible to drive a BIP 373 ignition driver through TC4427 chip?
MS3X uses a similar output chip for ignition outputs and can drive the BIP chips.
Yes, the TC outputs can be used to drive a BIP.
mancusogti8v
Post by mancusogti8v »
Does anybody build and sell a PNP driver "external box" ready to wire in? Kind of a Quadspark style.
I will be using MS3X and Audi COPs (NGK U5014).
Thanks,
Luis Roberto
prof315
Post by prof315 »
mancusogti8v wrote:Does anybody build and sell a PNP driver "external box" ready to wire in? Kind of a Quadspark style.
Thanks,
Luis Roberto
Get an MS3Pro instead of the 3X and you can use the VAG coils without an external driver box
Support the developers!
mancusogti8v
Excuse my ignorance...
Why will a MS3Pro will drive the coils and not a MS3X? (both directly)
Luis Roberto
Thanks,
Luis Roberto
mancusogti8v wrote:Excuse my ignorance...
Because the MS3-Pro uses a different circuit and was designed to be able to drive these coils.
mancusogti8v
Thanks for the explanation.
The problem I have is that I already have the MS3X (with Mapdaddy and knock control). :? :? :?
So the alternative is via external box.. I can solder and follow wiring diagrams, but building a circuit...(as of now beyond my abilities).
Luis Roberto
dontz125
Post by dontz125 »
Go with the TC4427. There really is no circuit building, just one 8-pin IC and two resistors per two channels. Take a look at section 5.3.1.3 of the MS3 manual; the actual diagram is on the following page.
mancusogti8v
Let me see:
I buy some stripboard, 15 ohms 1/4 resistors then
http://www.digikey.com/product-detail/e ... -ND/418665
And then build this (attached image)
mancusogti8v
Following the diagram in the previous post... my first attempt....
mancusogti8v
I know the soldering is far perfect
please if you catch any error, let me know....
I am going to tap into 5V of the TPSREF and tap into any MS grounds.
