Median noise filtering
Ive been using 3.2.1 since gslender released it and didnt want to upgrade to the newest version because of the median filter function, I have tps noise that only the median filter works to effectively eliminate any spikes (100% tps based AE). I wonder if this function will be implanted for the future releases.
Re: Median noise filtering
The current code implements an over-sampling feature on TPS.
Is your wiring correct in-line with the grounding directions in the manual ?
gonna try this out, the wiring is okay, i just dont know about the oversampling feature for the latest release, thanks.
Hallo James,
coudn't find the release not, can you maybe tell me since which firmware version the ADC oversampling was implemented and which channels (tps, map, etc.) have that feature.
Thanks very much and sorry that i did not found it in the search
Best regards
Malte.
Best regards
Malte.
Honda CRX B16A1 Turbo | MS3 running | pre1.5.1 beta7 Firmware | 24/1 Dual Wheel | COP ignition | 725cc ID injectors
I believe the current Extra release code is 3.3.1 and can be found here.mrx79 wrote:Hallo James,
Best regards
Malte.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
You might want to hit "Refresh" on that page???kjones6039 wrote:I believe the current Extra release code is 3.2.5 and can be found here.
Just got my plexiglass belly button fogged up and couldn't see while my head was...... Well, you know.....jsmcortina wrote:You might want to hit "Refresh" on that page???
Fixed!! I think!
