MS2/Extra pre-3.4 alpha 3 released
To announce the release of "MS2/Extra Pre 3.4 alpha 3" - this is a new stream of development codes. Most of the changes here are the same changes as in recent pre-3.3.2 codes. This alpha code includes the CAN broadcasting also.
EDIT: ETA on this 3.4.x code becoming release is 6-12 months.
Who should use this code?
Experienced users wanting to test the new features.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since pre-3.4 alpha 2
Bug fixes:
Re-arrange memory usage to (hopefully) prevent a stack overflow.
Apply same CLidle target change from MS3 to fix "stuck" problem after start.
Fix decimal places on testdwell
The memory change is the big change here. A large chunk of code from main() has been moved to a function. I have scope tested spark and injector timing. The code ought to run your engine identically to 3.3.x - if it does not, or you spot any other weirdness, please report it here immediately.
The zip can be downloaded from:
EDIT: Removed. Please await pre-3.4 alpha4.
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
The current TunerStudio (2.6.0 or later) is required.
Bug fixes:
Re: MS2/Extra pre-3.4 alpha 3 released
Used the new code a few minutes ago. Tried to reproduce the stackoverflow error but haven't been able to do so.
Great job James!
I'll be playing around a bit and will keep everyone updated about this version. The stackoverflow seems resolved (at least in my case).
Great job James!
[s]Porsche 924 ITB to be squirted...[/s] Successfully squirted the 924 (2008), crashed it on the Nordschleife (2010), trying again on a new 924 (2014).
so far this seems working very well, no errors - super coding James!
The CAN broadcasting is just too perfect, I love it - hopefully never have to back to "serials" anymore.
If any help for anyone, attached my MSQ and the Dash2pro .CAN file (SaveAs and remove the .MSQ extension). The .CAN file contains my CAN receive parameters in Dash2pro config file format.
Thanks!
Thanks!
Does the DASH2Pro support loading of .DBC files ?
I have the software here to create those maps of signals and messages. I was planning on creating them for MS2 and MS3. It is my understanding that some/many aftermarket CAN packages can read those files to understand available data.
yes it seems able to import .DBC files, yet not export though...
hy,i updated from alpha 1 and now in tunerstudio it shows me that itis not synced.only thing it shows is that running
I'm guessing that you haven't read the RELEASE-NOTES.txt file. Please read it.razvanypo wrote:hy,i updated from alpha 1 and now in tunerstudio it shows me that itis not synced.only thing it shows is that running
James, strange thing here:
loaded this new alpha, then the msq I was using before.
This "Difference Report" window appear and also if I hit "Send Current TunerStudio Settings" this window appear again and again, as if MS can't accept my RPMs values.
(this issue could be related to the latest TS beta (2.6.01) instead of MS firmware ?)
Thank you.
Fabio
Thank you.
Fabio
Yamaha V-Max V4 paired odd-fire 1200cc engine - ITB - COP
MS2/Extra Pre 3.4 beta 11
Sequential spark & fuel - ITB Algorithm
.dbc importing works on all Race Technology CAN adapters (Dash2Pro, DataLoggers DLx, and Video Systems...). I don't know how to write them though. What tool do you use?jsmcortina wrote:Does the DASH2Pro support loading of .DBC files ?
PS: I am on MS3 but never mind.
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
Have you seen this issue with other firmware versions?Fabius72 wrote:James, strange thing here:
I also am seeing it with pre-3.4 alpha3 and TS 2.6.01 now that I've been testing. I have only just started investigating.
No James, never seen it before.jsmcortina wrote:Have you seen this issue with other firmware versions?
The latest firmware loaded was 3.3.2 beta9 some days ago to try some things on the bench. No strange things found (with the same TS beta version).
Now I'm reloading beta9 and then 3.3.2 release to see a difference behaviour with the same msq.
I let you know.
Fabio
It seems firmware related to me.Fabius72 wrote:No James, never seen it before.jsmcortina wrote:Have you seen this issue with other firmware versions?
Repeatable on pre-3.4 alpha 3.
Not seen on 3.3.2
Just finished.Fabius72 wrote:...
I let you know.
Fabio
3.3.2 beta 9 and 3.3.2 Release have worked normally, as expected.
Race Technology suggested CANoe from Vector GMBh. It is a 1gig download though...!thokes82 wrote:.dbc importing works on all Race Technology CAN adapters (Dash2Pro, DataLoggers DLx, and Video Systems...). I don't know how to write them though. What tool do you use?
I found the bug. A very simple typo, but renders all existing pre-3.4 codes as junk because data is misaligned. I'll put out a new version today.Fabius72 wrote:Just finished.Fabius72 wrote:...
I let you know.
Fabio
Does this mean that also the .MSQ-files, created with the previous pre-3.4 alpha 1 to 3 -versions, are junk for the new alpha 4 -version?jsmcortina wrote: I found the bug. A very simple typo, but renders all existing pre-3.4 codes as junk because data is misaligned. I'll put out a new version today.
Just found a bug in the injector test mode stuff. When the Injector count gauge counts down to zero it loops to 16242ish and stays there. The injector stops triggering but the gauges is bouncing around. Not sure if this is present in 3.3.2 or 3.4A4...
