MS2/Extra pre-3.4 alpha 4 released
To announce the release of "MS2/Extra Pre 3.4 alpha 4" this follows pre-3.4 alpha3
ETA on this 3.4.x code becoming release is 6-12 months.
b]Who should use this code?[/b]
Experienced users wanting to test the new features.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since pre-3.4 alpha 3
Bug fixes:
'char' was missing from a var decl causing flash pages to be misaligned.
Changed features:
Reduce serial timeout to 25ms.
Reload from flash to RAM after a Burn to allow TS to CRC check data.
Minor/internal:
none
The zip can be downloaded from:
http://www.msextra.com/doc/ms2extra/fil ... alpha4.zip
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
The current TunerStudio (2.6.0 or later) is required.
Bug fixes:
Changed features:
Minor/internal:
none
Re: MS2/Extra pre-3.4 alpha 4 released
Known bugs. (yes, already!)
If more than 5 "groups" are enabled in CAN outpc broadcasting, the code sends the final group continuously. Fixed for the next alpha.
6cyl COP (even or odd fire) seems to have a 2.5v double pulse on Spark E and F instead of the 5v single pulse I'd expect. Spark A-D work fine.
This is a new setup, so I will keep going back to older firmwares and let you know what I find.
1990 Mazda Miata: GM Gen3 V8 swap, 4.8L, custom cam, 2x GT2860R turbos, MS3 + MS3X.
2003 Kia Rio wagon: Mazda B6T/G25MR swap, Miata CAS, IHI RHF5 @ 2bar, LSx truck coils, P&H board, boost control.
Check your hardware because the CPU cannot output a 2.5V signal.
You are correct. A small strand of wire had fallen on the processor.
v2.2 box, ms2, dual wheel, sequential ignition, staged injection, boost control, maf
'87 VW scirocco, 2L16V, TD0-14T turbo, itbs
James, how much NTC temperature sensors MS can serve? By default CLT and MAT. No more other? Like temp of fuel, temp of oil and other? Just only for logging.
For logging you can use a transform function in TunerStudio (somehow) to convert a raw ADC value from ADC6 or ADC7 and datalog it.
hello.can pls tell me how to start fan cooling when i activate ac ?i have fidle conected as fan throught a relay and it is set to start at 98 degrees celsius and i want to engage when i start ac.what is the condition in programable menu to activate it?
Hi
Is this a Bug?
The Boost Duty stay by 0% when Boost build on and jump to 100% if I do not expect it?
I have a solenoid when no Power (12V) is stay close and full boost.
My Boost settings "Inverted" and "Use Inital Valu Tabel".
When i switch to "No Inital Valu Tabel" my Boost Duty works OK, Boost Duty stay by 100% when under Target Boost.
Frank
Is this a Bug?
Frank
I think sequence batch is not working correctly my scope is bad so i can not be sure but in the jim stim if I select sequence batch start always in the same trigger point the output of the led do not look firing in the correct alternating order. I have try the stable code the beta and now this one and is present in every one. I am trying to have 2 event alternating that always starts in the same trigger with a 12 + 1 trigger setup. Can anyone check with a scope to see if the can replicate the strange behavior.
I use 2 alternating time mask 0 and trigger 1
Juan
Juan
I have a problem using boost control. With every setting of the basic slider i can't get the right pressure, it always oscillates. And also using the advanced mode with only P and I, i've always huge spikes in duty that goes to min dty and max duty.
The slider is supposed to work also on advanced mode?
And also, i've a problem with the target afr1 target gauge, it's stuck at the 14:1 value. I've already tried to recreate the dashboard...
Enrico
Opel/Vauxhall Corsa GSi MS2
Subaru v4 EJ20 MS3
Subaru v4 EJ20 MS3
Sorry, by now i don't have a datalog of the testing with the boost control, but with basic setting, i've started from 0 of the slider to the max value, and the pressure was always oscillating. I've also tryied variyng the control interval from 50ms (20hz valve frequency) to 100ms.
For the afr1 target gauge not working, i need to check if also in the datalogs there is the problem.
By now i can't provide logs as a out-of-spec brand new injector has a scarying low flow rate vs the others and it have destroyed (luckily only...) a spark plug, but now the seller of the injectors is in vacation, so no way until semptember
Always check flow rate of the injectors!
Enrico
Subaru v4 EJ20 MS3
Subaru v4 EJ20 MS3
Hello,
I´m using version 3.2.1 on my rotary 12A, and i was looking to update the firmware, but from what i have read this 3.4 alpha 4 also have some things to correct,
and there is also problems affecting releases before this one that were noted now.
Since i´m planing to remove the 12A and install a 13b 6 Port with turbo, the idea is to first use it on the old engine and have it tested before the 13b is ready.
Is there any plan for a release in short time (1 or 2 months) ?,,,, if not, what software version is more stable (higher than 3.2.1) for the Wankel engine ?
Tanks in advance.
Regards
Rx-S7V7N
Tanks in advance.
Regards
Rx-S7V7N
James, is it possible to add fuel consumption equation to CAN dashboard? Its very usefull with VDO dashboards in many cars with CAN.
Code: Select all
Fuel consumption (liters/sec) = RPM * injector open time * injector flow
I'm not quite sure what you are asking, but the current release code is available from the Downloads page linked above.RX-S7V7N wrote:Hello,
Regards
Rx-S7V7N[/quote]
Do you have the message format for that ?acab wrote:James, is it possible to add fuel consumption equation to CAN dashboard? Its very usefull with VDO dashboards in many cars with CAN.
Code: Select all
jsmcortina wrote:Do you have the message format for that ?acab wrote:James, is it possible to add fuel consumption equation to CAN dashboard? Its very usefull with VDO dashboards in many cars with CAN.
Code: Select all
Yes, its already implemented. But nobody use full functions
For example in my Alfa, we in packet 0x561 use only RPM and CLT.
Code: Select all
// fuel consumption
// 0x561 8 00 00 00 00 xx xx 00 00
// xx = fuel consumption 0-132 L/hour
Which endian and what scaling?acab wrote:For example in my Alfa, we in packet 0x561 use only RPM and CLT.Code: Select all
// fuel consumption // 0x561 8 00 00 00 00 xx xx 00 00 // xx = fuel consumption 0-132 L/hour
EDIT: Please also don't be sharing copyrighted code on other forums.
