MS2 diy autotune CAN EGT
i thought i post it here so other might benefit from my learning curve
obviously first start up is not going whit out a hitch
it would be nice if the setup guide would have an separate A,B,C for both MS2 and MS3
http://www.diyautotune.com/downloads/ca ... an-egt.pdf
Re: MS2 diy autotune CAN EGT
That looks like you did not keep the default setting in your CAN device and enabled the serial communication. From what I can tell your PC is connected to the MS2 and your CAN-EGT is connected to the CAN bus going to the MS2. So you're not using the serial communication to talk to the CAN-EGT but the CAN bus.
Go in the CAN device tab in your project, select the CAN-EGT from the list and disable the serial communication. Also, without your project file, how you connected everything and knowing what you tried to do this is just guessing.
like you said
PC-serial-MS2-can-CAN/EGT
i did not change anything as the message was the first that popped up
when i changed the device ID to 1 i lost the connection or at least i think i did
You need to change the CAN ID from the default '0' to the CAN-EGT ID which is '1'. The way you have it now, you're telling TS that your MS2 CAN ID is 0 at the top and that the CAN-EGT ID is also 0. This will result in TS trying to communicate to the MS2 instead of the CAN-EGT.
By the way, leave the Main controller CAN ID to 0 as it is now (top of the screen).
ah i think now i am getting somewhere
That looks good.
Any unconnected EGT input will show up as the maximum possible temperature. If you want to change that, you can put a short wire between the '+' and '-' inputs on all the unused EGT inputs: that should give a temperature close to the board temperature.
really want to try this out with a LC1 connected
but first have to get it from the engine
i don,t suppose you have an idea ho to get the data to be viewed in shadow dash?
I've never used Shadow dash so Phil or someone else with experience on it will have to answer. Can it see CAN devices? That's not necessary but that could be useful.
