It is even possible to backport it to ms2?
thanks Frank
feature request: boost delay timed after launch
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
Re: feature request: boost delay timed after launch
+1 I would like this feature too.
How would you expect this to work? You should have a min boost level when the boost valve is active then when the valve is toggled to increase the boost to the target value. How much delay are you asking for?
ol boy wrote:How would you expect this to work? You should have a min boost level when the boost valve is active then when the valve is toggled to increase the boost to the target value. How much delay are you asking for?
something similar to this will be perfect!!!!
https://www.youtube.com/watch?v=2V3NEa6 ... TPBAVU6tZA
First thing the guy said in the video is he's base firmware is 3.3.0w.
Yes is just for showing the idea, something like that will be perfect because it will do the job we do with this http://www.ams1000.com/index.php?option ... &Itemid=60 If I can control the time and how aggressive the boost rise I can control a car after launch (drag race application) to not spin the tires. Not to mention the $$$$ we can save and how simple the installation it will be if we can do all with the same unit (microsquirt in my case)ol boy wrote:First thing the guy said in the video is he's base firmware is 3.3.0w.
thanks,Frank
