Being no stranger to custom projects, my answer is usually of course I can make it run.
This project is unusual enough that I decided to write about it, it started up and ran for the first time last night.
BMW M70 5 litre V12 engine in an E30 body. Twin throttles, stock throttle bodies converted to cable control. One throttle body fitted with TPS. Twin MAP sensors, each plenum gets its own MAP sensor to compensate better for any errors in balance between banks. Two Ford 6 cylinder waste spark coil packs. Custom firmware to make it all work.
BMW M70 V12 on MS2-extra
Baldur Gislason
Re: BMW M70 V12 on MS2-extra
Why don't you go for ms3?
MS3 only supports 8 injectors and 8 coils so going sequential or coil near plug wasn't an option, so there wouldn't have been any improvement in going MS3 over MS2.
Baldur Gislason
Not so.baldur wrote:MS3 only supports 8 injectors and 8 coils
See: http://www.msextra.com/doc/pdf/html/MS3 ... .3-49.html
Shows how much attention I've been paying!jsmcortina wrote:Not so.baldur wrote:MS3 only supports 8 injectors and 8 coils
Baldur Gislason
