"Rev limit TPS bypass %"
The "help" suggest to use a value above 100 in order to disable this option, but when I try something above 100 it will ask to keep it <=100.
rev limiter settings bug
97 1.8T DIYPNP Seq Inj
http://megamiata.blogspot.co.il/
Re: rev limiter settings bug
I've adjusted the upper limit in the ini file for the next release.
Can I do the same ?
Yes. Make sure the project is not open is TS, then open the mainController.ini in your projectCfg folder using WordPad or something similar (for your sanity, DON'T use NotePad ...), and search for the following line:
Change the 100 to something higher, like so:
Open the project in TS, and set the bypass % to something over 100%.
Code: Select all
TpsBypassCLTRevlim = scalar, S16, 44, "TPS %", 0.10000, 0.00000, 0, 100, 1 ; * ( 2 bytes)
Code: Select all
TpsBypassCLTRevlim = scalar, S16, 44, "TPS %", 0.10000, 0.00000, 0, 200, 1 ; * ( 2 bytes)
