Is there anyone that can help me configure a base tune to start with on my car? Its a turbo 94 cobra using MS pnp gen 2. I am going to be starting at a low boost setting, probably 6-8 psi. I was hoping maybe sombody can setup a file with alot of timing pulled and some extra fuel so I can work my way back. Im afraid ill hurt the car trying to go from a stock tune forward that would be lean and too much timing for boost.
Its a fairly basic setup-
e85 fuel
stock 351w
s480 turbo (1.32ar/96 turbine)
th400 transmission
the only parts on the engine are a efi carb style intake with an elbow and 70mm throttle body. I am more than willing to pay for somebody's help getting me going. I am familiar with tuning NA on my old moates QH setup but not comfortable yet with boost and megasquirt.
Thank you
Austin
base tune
Re: base tune
Where are you located? Is this a SBC motor?
Re: base tune
351W tends to be a bit more FoMoCo than SBC.
Cheers Luke
Cheers Luke
Re: base tune
Looks like I over looked that and only saw the th400 (Chevy) part.
