To announce the release of "MS2/Extra Pre 3.4 alpha 8" this follows pre-3.4 alpha7
ETA on this 3.4.x code becoming release is 6 months.
Who should use this code?
Experienced users wanting to test the new features.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since pre-3.4 alpha 7
Bug fixes:
Allow 16 inj in ini file.
Changed features:
Major CAN re-write.
- TX is polled not interrupt driven
- TX messages built in full in advance
- TX code just grabs pre-made message and loads registers
(CAN OUTMSG feature untested.)
Add serial DEBUG facility. ('d' 'D')
Minor/internal:
As noted above, this firmware includes a big re-write of the CAN system which we believe gives far more reliable passthrough operation.
The zip can be downloaded from:
http://www.msextra.com/doc/ms2extra/fil ... alpha8.zip
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
The current TunerStudio (2.6.0 or later) is required.
MS2/Extra pre-3.4 alpha 8 released
Re: MS2/Extra pre-3.4 alpha 8 released
James, i forget about little bug with using JS10 for SparkA. When make ignition ON - SparkA give spark and SparkB are fine. I mean, i just power on ms2 and didnt crank engine.
I can use LED14 for SparkA, but now i cant do that.
Using JS10 for Spk A while using multiple spark outputs isn't desirable. I didn't thing it would work at all. The recommended method is to use D14.
Sorry, i forget about msq. I have old one there. Its not are different.jsmcortina wrote:
I have only 2 channels of injector and spark.
tested and works as fine as alpha7, e.g. CAN Realtime Data Broadcasting to the Dash2Pro with 10Hz - nothing odd found so far.
Fine tuning ongoing with the injectors timing with Fuel VE & Accel Enrich and WUE: ´´´too lean...too rich - ahh the smell of E85 exhausts in the garage is killing - few hours per day is enough
Attached msq and some start-idling-revving log data: appreciate if like to point any abnorm settings etc.
Thanks James!
Thanks James!
