EDIS testers needed
(Runs on MS2 and Microsquirt)
EDIS testers needed
The current MS2/Extra alpha code: http://www.msextra.com/forums/viewtopic ... 91&t=57121 contains a re-write of EDIS mode. We need some on-engine feedback that this is operating correctly.
If you are using EDIS on MS2, Microsquirt, Microsquirt-module and are willing to test, please do so and post up your results. Confirming your timing with a light is essential.
sully32
Re: EDIS testers needed
Post by sully32 »
James,
I just saw this thread and I'll give it a whirl. I'm still running EDIS on my M10 but I won't be able to update and test until next week.
-Shawn
87quest-TSI
Post by 87quest-TSI »
I'm running this code with eds and all is good so far.
Theirs a bit more info on this post.
http://www.msextra.com/forums/viewtopic ... 33&t=56853
89,88,87 Conquest TSI
1971 Jeep CJ5
MS2-V3.57 with map daddy, software 3.4.2 with EDIS on a Mitsubishi 2.6l turbo.
using Tuner Studio V3.0.28 / megalog viewer V4.1.17 and Shadow Dash V1.5.02
wes kiser
Post by wes kiser »
I have access to a vehicle running EDIS with a microsquirt module. Does this still provide value to test?
87quest-TSI
Thought I would do a update for this code.
My car is still running good with this code. It starts better then it did before this code as well as idling better. On the older code it sounded like it had a random miss. It also fixed a hit or miss stalling problem when you started to let out the clutch.
Thank you for your hard work and trying to improve the code.
1971 Jeep CJ5
shadowplane676
Post by shadowplane676 »
Once I get my setup re-tuned in it's new body again, I'll try the Alpha code. I have been running EDIS for at least 5-6 years with my setup.
