The current MS2/Extra alpha code: http://www.msextra.com/forums/viewtopic ... 91&t=57121 contains a re-write of EDIS mode. We need some on-engine feedback that this is operating correctly.
If you are using EDIS on MS2, Microsquirt, Microsquirt-module and are willing to test, please do so and post up your results. Confirming your timing with a light is essential.
EDIS testers needed
EDIS testers needed
Re: EDIS testers needed
James,
I just saw this thread and I'll give it a whirl. I'm still running EDIS on my M10 but I won't be able to update and test until next week.
-Shawn
-Shawn
I'm running this code with eds and all is good so far.
Theirs a bit more info on this post.
http://www.msextra.com/forums/viewtopic ... 33&t=56853
89,88,87 Conquest TSI
1971 Jeep CJ5
MS2-V3.57 with map daddy, software 3.4.2 with EDIS on a Mitsubishi 2.6l turbo.
using Tuner Studio V3.0.28 / megalog viewer V4.1.17 and Shadow Dash V1.5.02
1971 Jeep CJ5
I have access to a vehicle running EDIS with a microsquirt module. Does this still provide value to test?
Thought I would do a update for this code.
My car is still running good with this code. It starts better then it did before this code as well as idling better. On the older code it sounded like it had a random miss. It also fixed a hit or miss stalling problem when you started to let out the clutch.
Thank you for your hard work and trying to improve the code.
1971 Jeep CJ5
1971 Jeep CJ5
Once I get my setup re-tuned in it's new body again, I'll try the Alpha code. I have been running EDIS for at least 5-6 years with my setup.
