Cam trigger that coincide with crank trigger
(Runs on MS2 and Microsquirt)
masterx81
Post by masterx81 »
Hi!
Out there there are some engines that have the cam edges really close do crank edges. As i've understood it (speaking about the n-1 configuration plus 1 tooth cam signal before the pms) ms have an isr for the cam trigger and one isr for the vr trigger, if both fire together isr cam together weired things can happen due to the delay of the isr that came last.
Last engine with this problem i've had to redrill the crank pulley....
Isn't possible to enable a new mode that instead of waiting an isr, we check the level of the cam signal on the crank isr, so that there isn't a second isr that interfere?
Really thanks!
Enrico
Opel/Vauxhall Corsa GSi MS2
Subaru v4 EJ20 MS3
AbatelliCristian
Re: Cam trigger that coincide with crank trigger
Post by AbatelliCristian »
I have test in fiat 500abarth with MS3. The engine start well in full sync, but in first test, I noticed low power respect previous ecu...I have not done a fine tuning to the dyno, but first impression is low power and high EGT. I don't know if the problem is the tune (I had little time to test) or is there really a problem.
BestRegards
Cristian
Post by jsmcortina »
masterx81 wrote:Isn't possible to enable a new mode that instead of waiting an isr, we check the level of the cam signal on the crank isr, so that there isn't a second isr that interfere?
"Poll level" already exists. Is that what you mean?
Perhaps posting a composite log would help.
AbatelliCristian
In my test I dont have used poll level, but I use rising adge...
I will make new tests more accurate
masterx81
Post by masterx81 »
So poll level do already this? So that the edges of cam and vr can be together?
Whops, missed that, nice!!!
Thanks james, never used that setting!
Enrico
Subaru v4 EJ20 MS3
