MS2/Extra pre-3.4 beta 10 released
To announce the release of "MS2/Extra Pre 3.4 beta 10" this follows pre-3.4 alpha9
ETA on this 3.4.x code becoming release is 3 months.
Who should use this code?
Experienced users wanting to test the new features.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since pre-3.4 alpha 9
Bug fixes:
Fix ini offsets for CAN IDs for polling.
Fix CAN digi ports.
CAN MSG_REQ, MSG_REQX tweaks per Jean.
Fix can_build_outmsg to send only the needed messages and go through all elements
Changed features:
Add simplified "Dash Broadcast" for CAN.
Minor/internal:
ini tweak, MAP phase sense tooltip.
FIDLE tooltip tweak.
The zip can be downloaded from:
http://www.msextra.com/downloads/dev/ms ... 4/beta-10/
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
The current TunerStudio (2.6.0 or later) is required.
Bug fixes:
Fix CAN digi ports.
Changed features:
Minor/internal:
Re: MS2/Extra pre-3.4 beta 10 released
tested and works as fine as alpha9, e.g. CAN Realtime Data Broadcasting to the Dash2Pro with 10Hz.
Have you had a chance to look at the "Oddfire First Angle" feature? http://www.msextra.com/forums/viewtopic ... 40#p432714 ...if can help to test etc.
Thanks!
Thanks!
I get bug ;(
Only 0x041 and 0x361 packets are sends
I replied in that topic.Buelliholic wrote:Have you had a chance to look at the "Oddfire First Angle" feature? http://www.msextra.com/forums/viewtopic ... 40#p432714 ...if can help to test etc.
Do you know what the last working version was?acab wrote:I get bug ;(
I should be able to test fairly easily once I'm back to my test bench.
I tested and it is working ok. Jamesjsmcortina wrote:Do you know what the last working version was?acab wrote:I get bug ;(
I have recently changed engine in my car to one with a lot more cam. About the same time I decided to give this FW a try. Previously I was running 3.3.1 which worked extremely well for me and was rock solid. With the change to beta 10 my serial connection became so unstable I could not tune the car as the drop outs were so frequent. I went back to 3.3.1 and it's rock solid again.
Have there been major serial changes between these 2 firmwares? I thought 3.3.1 was using the new serial?
Just bumping my question above about the serial changes in the post above.
Both 3.3.x and 3.4.x use "newserial". Nothing springs to mind that would have changed there on the firmware side.
Please attach "TunerStudioAppDebug.txt" from your TunerStudioProjects directory, it might shed some light on the situation.
I didn't have the debug on at the time. I will try to reload the beta on the weekend, get the debug.txt and post it up.
It could be useful even without the debug.slow_hemi6 wrote:I didn't have the debug on at the time. I will try to reload the beta on the weekend, get the debug.txt and post it up.
Ok I'll post up an extract from when I changed over from whats there. I started changing over just before mid day on the 3/4/15.
Bumpin it.
Something seems to be making TunerStudio very unhappy. I see several "SEVERE: null" whatever that means.
Probably best to do a comms log debug version and start a topic in the TunerStudio section.
