I'm quite new to Microsquirt. I know with some modification and msn extra software, we can run 4 cyl sequential. But can it be done with microsquirt? Or can I use GPIO to run 4 cyl sequential since there is enough hardware inside to run 4 injector? Thanks.
Regards,
Doddy
Microsquirt running sequential 4Cyl
Re: Microsquirt running sequential 4Cyl
To run sequential injection you need either an MS2 with the needed modifications and additional drivers or a Microsquirt module with additional injector drivers.
So it have to be ms2 or microsquirt module then.
Yes, as Jean say you also need the additionnal drivers. For MS2 (v3.0 is prefered) you can look at280GE 1JZ wrote:So it have to be ms2 or microsquirt module then.
High-Z injectors :
http://www.jbperf.com/quad_ign_inj/index.html
Low-Z injectors :
http://www.jbperf.com/p&h_board/index.html
Cheers,
Manu
