stumbling and hesitation
Long shot...but here we go. Car is a e30 bmw turbo. Has been running beautifully for 2 yrs. It stared to hesitate and stumble horribly i hooked up laptop to megasquirt and laptop completely died in the process. So now i have to buy another laptop and I'm stuck trying to figure out what going on. I bought new plugs, plug wires...i ohm'd the crankshaft sensor and its working correctly ..i also ohm'd the TPS and also within spec. Fuel pressure is perfect. Drives like its on 5 cylinders ....starting to think maybe the MAP sensor might be out. I blew through map hose and no leaks. Crappy not having the laptop at my disposal...any help or thoughts would be appreciated ..thanks.
Re: stumbling and hesitation
Bummer....... Not too much we can do without a log, I think. When you get that new laptop going, post one up.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Ok, so finally got the logs. At the time of the log my 02 sensor went bad because of how rich it had been. So I'm still sending the log. Im suspecting the Map sensor...But I'm a newb. Remember the car has been solid for 2yrs. Then all of a sudden it started to have a range of issues that make it undrivable.
Ok , finally did a proper log and tune with the new o2 sensor installed.
The MAP readings in the second log are seriously weird. What does it read with the key on and engine off?
