hello people
i wanted to use ams2000 but i decided to use my microsquirt v3 to control boost as i use it as a standalone ecu to control ignition ,fuel ,airshift ,launch ,etc....
is there any way we can add to the code a boost per gear ?or boost vs time after launch ?or any thing to make boost control more effective ?
i know you can use boost vs speed with the ms3 but i didnt find that option with 3.4 code or the 3.3 unless there is a code that i could use that would have these options
if i can use boost vs speed then how can i get the signal from my speed sensor to the microsquirt ?
i know some members use msdroid and use there phone as gps for speed but i would like my microsquirt to have more stable signal
any advice would be great
cheers members
boost control with microsquirt v3
Re: boost control with microsquirt v3
There is no option in the MS2/Extra code at this time for boost vs gear, speed, or time. I assume you're trying to avoid lighting up your tires with too much boost in first gear?
I have an accessory module that's ready for field test that acts as a 2-stage boost delay timer. While launch control is active, boost control is limited to value 'a' psi; for the next x seconds after launch control is released, boost control is limited to 'b' seconds. Once I've cleared out my back orders (hopefully today!), I'll start looking for testers.
im very interested and yes i have a big problem with tire spin and wheelies in first and second gear
how can i order or buy that unit ?
More speed -> more boost? But if you measure RWD car speed from rear wheels you may got spin -> more spin.
i think i would you the speed sensor to turn it as a gear ratio
so at example a speed and b rpm will give be c boost and i will keep tuning it down till i have no spinn or wheelies
but i really like the time base idea i want one asap
PM sent.
cheers
will keep you people posted on how this will work
