ms2 3.3.3 wasted cop wiring (edited*)
(Runs on MS2 and Microsquirt)
juansh2385
Post by juansh2385 »
So I notice something strange or at least not expected. In the release version 3.3.3 if you select wasted cop the code fires output A and C at the same time and output B and D. I know the sequence is ABCD. Normally for wasted spark I only use output A and B and wire all the 4 bip to only 2 processor pin but in this case I try using 4 processor pin and found this behavior.
Juan
racingmini_mtl
Re: ms2 3.3.3 *Bug* wasted cop
Post by racingmini_mtl »
Wasted COP uses 4 outputs fired in pairs; wasted spark uses 2 outputs. That how it works.
juansh2385
Jean i know that wasted cop fires in pair that is the point. What i notice strange was the pairs. Instead of A and D firing a the same time the current implememtation fires A and C. I would expect that if i wire the car for cop and for some reason I would need to switch beteween coil on plug and wasted cop setup the wiring could stay constant and just change setting ritgh now that is not posible
jamies
Post by jamies »
I think the OP may be confising the situation
ABCD
1342
ABAB
ABCD
A-C is one wasted pair
B-D is one wasted pair
so essentially makes no difference to the operation if its wired from two or 4 outputs
if A-D fired as pairs you would have the D cylinder mistimed.
Re: [Not a bug] ms2 3.3.3 *Bug* wasted cop
Post by jsmcortina »
As Jean says this is exactly how wasted-COP is supposed to operate and IS the same wiring as COP.
juansh2385
Re: ms2 3.3.3 wasted cop wiring (edited*)
Thank for clarifying after I pair abcd to the corresponding cylinder it became obvious that I made a mistake.
Juan
