I'm currently mount a MS2 on a Peugeot 505 V6 car. This car have a trigger wheel with 60-2-2-2 pattern. This pattern is very similar to Renix 66-2-2-2. The motor is the same. We won't do COP because the motor will keep 'stock'.
Trigger wheel pattern : 60-2-2-2
each tooth is 6°
the pattern 20-2 is repeated each 120°. There is 18 tooth and 2 missing ones, for a total of 20 each 120°.
Based on old Renix code, I make several changes to match this pattern. The code compile well. Can you please tell me if I do a mistake ? I want to be sure before flashing the code to the MS. Here is my new code :
Code: Select all
/* ---------------------- Peugeot 505V6 60-2-2-2 ------------------------*/
} else if (spkmode == 16) {
no_teeth = 18; // for single coil
last_tooth = no_teeth;
no_triggers = 1;
deg_per_tooth[0] = 60; // 6° degrees per tooth
deg_per_tooth[1] = 60;
deg_per_tooth[2] = 60;
deg_per_tooth[3] = 60;
deg_per_tooth[4] = 60;
deg_per_tooth[5] = 60;
deg_per_tooth[6] = 60;
deg_per_tooth[7] = 60;
deg_per_tooth[8] = 60;
deg_per_tooth[9] = 60;
deg_per_tooth[10] = 60;
deg_per_tooth[11] = 60;
deg_per_tooth[12] = 60;
deg_per_tooth[13] = 60;
deg_per_tooth[14] = 60;
deg_per_tooth[15] = 60;
deg_per_tooth[16] = 60;
deg_per_tooth[17] = 180; // double missing tooth = time * 3
smallest_tooth_crk = 60;
smallest_tooth_cam = 0;
trigger_teeth[0] = 14;
trig_angs[0] = -120 + tmp_offset; // 12 ATDC
/* ---------------------- Suzuki swift ------------------------*/
I will adjust the offset (if needed) using a strobe.
At least, I'm currently at the customer house and I'm a little urged
Best regards,
Manu
