Suzuki Baleno crank trigger wheel in wasted spark mode
Hey all this is the first time i'm posting on this site,i usually come on here actually everyday just browsing around checking the latest developments but now i'm here asking for some assistance. I have a 1999 Suzuki Baleno with 1.6L 4 cylinder bottom end with Twin cam 16 valve head fitted and running dizzy with Ms2 controlling both fuel and ignition. I'm in the process of setting up a wasted spark system utilizing 4 Denso coilpacks from a Toyota yaris coil part #90919-02240, a crank angle sensor and crank gear with trigger wheel integrated from a 2000 Suzuki Baleno which uses 2 coils to 4 cylinders. What i'm trying to find out is if the Baleno trigger wheel is supported within MS2 extra code because of the funny shape if not is there another way around it. I'll post pics of the trigger wheel as well as one of the coils below any help would be greatly appreciated.
Re: Suzuki Baleno crank trigger wheel in wasted spark mode
That looks like 36-2-2-2. I'd need to count the gaps to be sure it will work as there appear to be two variants.
Baleno has the same trigger as subaru. I have done three of them. Works perfecly with ms.
