Hello,
I would like to know if it will be possible for developers to consider that, when using a Microsquirt or a Microsquirt Module with a single coil setup, IGN2 can't be used.
In this setup case, which is common, IGN2 could be used, for exemple, as a programmable output if fitted with the correct circuitry. Is there a possibility to take this in consideration ?
Best regards,
Manu
Microsquirt & µSM IGN2
