it would be great if I could choose TPS for MAF input port.
Reason: My car has an airflow sensor and no TPS.
I need ADC6/ADC7 for other sensors.
Also I would like to retain the map sensor.
Jan
Feature Request: TPS for MAF Input Port
Re: Feature Request: TPS for MAF Input Port
Have you tried selecting alpha-n for primary fuel with your MAF wired up to the tps line? You could still tune the car using the output from the MAF on the y axis and rpm still on x. Id try it at least once. You might be onto something...
Will NOT work... You will not get any kind of useable resolution for fueling. If using a MAF, use MAF mode...
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
