MS2/Extra pre-3.4.1 beta 1 released
(Runs on MS2 and Microsquirt)
Post by jsmcortina »
To announce the release of “MS2/Extra Pre 3.4.1 beta 1” this follows 3.4.0 release
Who should use this code?
Experienced users wanting to test the new features or users experiencing bugs fixed by this version.
Who should not use this code?
New or casual users – please use the current release code instead – see the Downloads page linked above.
Main changes since 3.4.0 release
Bug fixes:
Trigger return typo.
CAN passthrough 256 byte fix from MS3.
Fix bug in PWM idle dithering code that could cause a long delay before duty took effect after start.
Changed features:
Ski doo PTEC 24+1+1+1+1 wheel mode. 2-cyl 2-stroke. (experi)
More CAN passthrough checks from MS3.
Add 6cyl variant to 36-2-2-2
Remove can_reset setting and replace with CAN error counters exposed in outpc.
Minor/internal:
The zip can be downloaded from:
http://www.msextra.com/downloads/dev/ms ... 4-2/beta1/
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
The current TunerStudio (2.6.0 or later) is required.
ol boy
Re: MS2/Extra pre-3.4.1 beta 1 released
Post by ol boy »
James,
I finally got back to running a 2 stroke using trigger return using 3.4.0. I got the engine to fire but I was having massive sync loss issues. I reverted back to 3.4a4test code we were working on for a year ago and the engine runs fine with out any sync loss issues.
2015-09-08_14.16.28.msq
broke.msl
Did your bug fix with 3.4.1beta1 fix the sync loss or is this a different issue?
Thanks Ryan
Alfagta
Post by Alfagta »
With trigger return you must use 3.4.1 beta 1.
There was an fault in 3.4.0
Best Regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
ol boy
Post by ol boy »
Okay, ill give it a try when i get to work.
** Seems to have worked. Running this beta using trigger return with the kick start function.**
91hybrid
Post by 91hybrid »
I am working on a '91 Ford Mustang 5.0L Turbo. The car has a MSPNP2 controller for about a year. The car has been plagued with the uncontrolled high idle at startup (2500 rpm) using firmware version 3.3.1. I loaded 3.4.0 with no change in startup idle. Posting about he issue in this thread: http://www.msextra.com/forums/viewtopic ... 65#p450865 Matt Cramer posted about firmware version 3.4.1 that is to address this issue. I tried it last night.
Same tune in the car except for adjusting the Crank to Run Time from 1.5 to 3.5.
So good news!!!! The Car no longer takes off for the moon (2500 rpm) when it is started! Bad news.... It doesn't appear that the Crank to run time is working at all as I still can not see my duty cycle % rise at start and then lower to my idle setpoint (45.1%).
Here is the tune for the 3.4.1 and the "Hot Start" 3.4.1 Log and A startup 3.4.0 Log:
ruzki
Post by ruzki »
got the same problem ..crank to run is not working !
muythaibxr
Post by muythaibxr »
The duty should not rise at start then drop... IT should start wherever your cranking duty is, then drop off over the crank to run taper time.
If it's not doing that then you're probably not getting into closed loop for some reason.
ruzki
Post by ruzki »
and it is not doing it, there is no difference if it is set to 1 or 10s ..
In my case it is working like crank to cl idle.
And cl idle starts right after crank so crank to run time is completely ignored.
91hybrid
Post by 91hybrid »
muythaibxr wrote:The duty should not rise at start then drop... IT should start wherever your cranking duty is, then drop off over the crank to run taper time.
You're absolutely correct. I had lowered my Crank duty cycle % trying to get the 3.3.1 to stop reving to 2500 rpm. Thanks for setting me straight!
So tonight I readjusted the crank duty cycle and then fired her up. So good news is it seems to work correctly. The only thing that I noticed is the taper time initially appears to be off a power of 10. My taper time was set to 3.5 and looking at the logs the taper time was lasting about 34.5 seconds. Unfortunately I fried the starter on the last trial so I have not tried changing the taper time to 0.4 to see if I get a 3.7 second taper time.
Here are the logs and tune I was running:
EDS_5_OH
Post by EDS_5_OH »
Anyone have Coolant Temperature Sensor issues after the upgrade to 3.4.1? My CLT is off by a large amount now, when it should read 180 deg, it now reads 68 deg.
1993 Mustang, stock ford Coolant Temperature Sensor. My stock gauge reads normal and closely matches an aftermarket additional gauge I have in the car.
Make sure you recalibrate your MAT, CLT and AFR tables after loading the new firmware.
This is now released as "3.4.1 release"
Blown88GT
Post by Blown88GT »
EDS_5_OH wrote:Anyone have Coolant Temperature Sensor issues after the upgrade to 3.4.1? My CLT is off by a large amount now, when it should read 180 deg, it now reads 68 deg.
Upgraded from what version?
I upgraded from 3.4.0 to 3.4.1; no recalibration required .
GraemeD
Post by GraemeD »
Warnings after loading a 3.3.2 tune into 3.4.1 firmware; Can someone shed some light on what they are? they have not posted again after saving the tune from 3.4.1. I have not tried starting the car with the new firmware yet, but I am just curious as to what they were and where to go to resolve them.
:Warning: Parameter in .msq, but not valid for current firmware: No options found for Bit EcuParameter:IdleCtl_out equal to the proposed Normal
:Warning: Parameter in .msq, but not valid for current firmware: No options found for Bit EcuParameter:knkport equal to the proposed MS2 AD7/JS4
:Warning: MSQ Units Mismatch for smap_table2! % found in current configuration, INVALID found in MSQ, values were not converted to new units.
:Warning: MSQ Units Mismatch for fmap_table2! % found in current configuration, INVALID found in MSQ, values were not converted to new units.
:Warning: MSQ Units Mismatch for fmap_table2doz! % found in current configuration, INVALID found in MSQ, values were not converted to new units.
'94 Miata ; 2001 VVT engine; DiyPnp 3.4.1 & VVTuner , 99-00 crank & cam sensors; sequential Toyota COP ignition; LC-1 wide band O2; Square Top manifold; RB header; Custom CAI.
ol boy
Post by ol boy »
The only major change that would affect the ign system qould be the spark output. Going high or going low for your hardware setup. Youll need to retune idle i believe.
jrrodriguez211
Post by jrrodriguez211 »
Upgrading from the 3.4.0 firmware to the 3.4.1, all my sensors are off. The CLT and MAT are 20° F hotter than what they should be and the map sensor reads 30 kpa less than it should. Even after recalibration. Plugging in a different daughter board with the 3.4.0 code loaded reads correct temps and pressure. Is there some setting that I missed here?
GraemeD
Post by GraemeD »
moved
'94 Miata ; 2001 VVT engine; DiyPnp 3.3.2 & VVTuner , 99-00 crank & cam sensors; sequential Toyota COP ignition; LC-1 wide band O2; Square Top manifold; RB header; Custom CAI.
This beta is superceded. Use the 3.4.1 release instead. If you have any questions on that, start a new topic in the MS2/Extra Support sub-forum with MSQ and datalog as usual.
