Loading MS2 firmware on blank CPU. Help?
(Runs on MS2 and Microsquirt)
Snake____1
Post by Snake____1 »
Hi there,
My first post here and first real problem with my MS2 v3.57... I suspect after a bad jumpstart it fried my CPU "hasn't started since", everyting else measures fine but no serial connection.
Voltages, Resistors, Caps, Inductors everything measures up good.
Since this isn't my first rodeo with the heatgun and soldering, i replaced the motorola "freescale" chip no problems "I thought".
I bought A replacement at Mouser. http://no.mouser.com/ProductDetail/Free ... iTcg%3d%3d
And a USBDM cable from ebay http://www.ebay.com/itm/Freescale-DBM-X ... 3a9fedb8bc
Handy to have i thought. Loaded the bootstrap.s19 to my cpu via BDM, but no response when trying to use the download-MS2-firmware.bat
Anything I'm missing or doing wrong here?
Regards from Norway!
Pic for refrence
ol boy
Re: Loading MS2 firmware on blank CPU. Help?
Post by ol boy »
Do you think you need the serial monitor loaded first? If I understand correctly the only item needed is the serial monitor loaded through the BDM port. Then the bootloader and firmware can load through the TTL UART pins.
Snake____1
I've read up alot on this the last days. The understanding i got from all this is that i need the MS2 specific serial monitor uploaded via BDM. I have tried the HCS12 monitor from frescale, but i get an error when trying to load the firmware. I saw one of the admins on this forum uploaded it a couple of years ago, but he took it down again because of rights and so on.
Anyone have the monitor file ready for upload that i can borrow?
ol boy
Post by ol boy »
You should beable to us the standard one from freescale. My MS2 board is 7 years old. Im sure it was loaded with what ever serial monitor was avaiable way back then. I've progressed through 1.2 firmware to 3.4.1 with out any issues.
Snake____1
Hmm, strange.
Step 1 - Load HCS12_Serial_Monitor.sx "HCS12" monitor via BDM
Step 2 - Start MS2 downloader 2.0 via seial, read signature, no connection.. "BLD jumper connected"
Next try
Step 1 - Load Monitor_v3.108.abs.s19 via BDM
Step 2 - Start MS2 downloader 2.0 via serial "BLD jumper connected", read signature, Signature: "** V3.10Embedded Code by B&G **"
Step 3 - Load megasquirt2.s19 via serial with MS2 downloader, ERROR: Unknown error status response, e=0x56
I get the same results when using both MS2 downloader, download-MS2-firmware.bat or ms2loader_win32.exe...
Trying with both firmware 2.1.0e and 3.3.3...
The error on second try:
Post by jsmcortina »
Probably best to send it to a distributor/repairer and have them re-load the correct monitor.
Snake____1
And closest would be? UK?
Thanks for every reply guys!
It depends on where you are! Your forum "location" field is blank.
Snake____1
Oh, sorry! First post also states Norway :P
Regards,
Snake____1
Solution, sent out for repair.
