Acceleration Ignition correction
last week i had the opportunity to work with an Ecumaster Emu.
This ECU has a feature that is called "Acc.Ignition", picture attached.
It is obvious that tuning of the acceleration behavior of highly responsive 4 cyl. Engines, is only possible with a feature such this !
Yes ! maybe, in a lot of cases bad acceleration behavior is a result of bad tuning, but this cannot be a reason to omit this feature.
So my question is why the do the developers do not want to implement this feature ?
Georg
Georg
Re: Acceleration Ignition correction
Why is it obvious that tuning 4 cylinder requires this?
All I see is a picture with no settings from zero.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Peter !Why is it obvious that tuning 4 cylinder requires this?
Is this a serious question ? Do you expect an answer ?
Georg
I do.ruzki wrote:Peter !Why is it obvious that tuning 4 cylinder requires this?
Georg
This feature is requested from time to time, but usually with more evidence than you have provided.
Often people requesting this feature are using MAF for load, and it reacts too late for ignition timing when changing load.
Why is the need obvious?
Peter Florance
PF Tuning
PF Tuning
I'm curious about what would be different against setting the timing figure based on RPM and MAP?
@ Peter
@ DaveEFI
less torque during acceleration would be the effect
you have already answerd this question with this :Why is the need obvious?
.. because people are requesting it !This feature is requested from time to time, but usually with more evidence than you have provided.
@ DaveEFI
I didn't say I agreed with the evidence.
It would have been better if you have shown settings in your screen shot
Peter Florance
PF Tuning
PF Tuning
ruzki,
Plenty of people have requested plenty of silly things over the years.
Posting unsubstantiated requests helps nobody.
So, you want less torque?? Well take your foot off the throttle? Acceleration is by definition more torque/power than is required to maintain the current velocity.
I'm not even sure that is Ecumasters intended use for that feature. I'll ask someone I know who uses that product.
Peter Florance
PF Tuning
PF Tuning
The ECUs I have seen that need that feature need it because they do not use every tooth on their crank wheels to schedule timing, and don't have any prediction, so spark comes late on accel. We use every tooth and have prediction.
I want to make clear that i have not requested any feature ! Please read the first postPosting unsubstantiated requests helps nobody.
I got the impression that you people do not read anymore and jut switch on your "self-defense mode" .. but why ?
this post assures this
Again the question was:Plenty of people have requested plenty of silly things over the years.
Right !! and now tell this a womanSo, you want less torque?? Well take your foot off the throttle? Acceleration is by definition more torque/power than is required to maintain the current velocity.
I´m talking about highly responsive engine´s, 70mm inner Diameter Throttle Body on an 2.0 4cyl. for example, i bet non of us can push the gas pedal gentle enough to maintain a smooth acceleration from very low velocity.
ask me !I'm not even sure that is Ecumasters intended use for that feature. I'll ask someone I know who uses that product.
First good answer ! Thank you !The ECUs I have seen that need that feature need it because they do not use every tooth on their crank wheels to schedule timing, and don't have any prediction, so spark comes late on accel. We use every tooth and have prediction.
I'm done here.ruzki wrote:I want to make clear that i have not requested any feature ! Please read the first postPosting unsubstantiated requests helps nobody.
this post assures thisAgain the question was:Plenty of people have requested plenty of silly things over the years.So my question is why the do the developers do not want to implement this feature ?Right !! and now tell this a womanSo, you want less torque?? Well take your foot off the throttle? Acceleration is by definition more torque/power than is required to maintain the current velocity.
Peter Florance
PF Tuning
PF Tuning
Yep, troll alert.
I don´t think that i deserve to be called troll, just because i asked questions wich are not welcome ... but Ok ! i´m out ! ..byeYep, troll alert.
The only good explanation I've seen for this feature - when not being used as a correction for an ECU with a second rate wheel decoder - is to reduce driveline shock loads by making throttle response softer.
I have also seen a lot of baloney reasons people have asked for this.
You asked a question without giving the reasons why you though such a feature was needed?ruzki wrote:I don´t think that i deserve to be called troll, just because i asked questions wich are not welcome ... but Ok ! i´m out ! ..byeYep, troll alert.
If you have a particular problem MS related, plenty of experts here will help with it. Including those who actually write the software, who I, for one, am incredibly grateful to. Not many products on the market where this is the case.
There is always more than one way to skin a cat.
Just want to reinforce what Dave has already pointed out here. Where else in the automotive industry (or elsewhere for that matter) can you get direct access to the developers??? That ain't gonna happen anywhere else except on this forum, I don't think!!!
Dave,
Are you back to skinning cats again?
Dave,
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
It is meant to soften snatchy throttle response especially on responsive engine with manual transmissions to soften driveline shocks.
It can also prevent pinging when hitting the throttle hard after shifts, just by momentarily retarding ignition.
Most OEM systems use this also.
Probably most engines won't benefit from it, but I also have asked for this "tip in retard" function.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Innovate LC1 wideband lambda sensor
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Ah, I misunderstood the request. I was thinking that people wanted more advance when RPM is increasing faster. People have asked for that, and I've always thought of it as a band-aid for poorly written wheel decoders.
TPS rate of increase-based retard of ignition timing IMHO has merit, though again it is at least partially to account for the ECU and rest of the system's inability to keep up with fast increases in load. In other words the physical system changes faster than the ECU can sense, so you add a fudge factor to retard a little faster than the MAP changing in the manifold, the sensors ability to sense the change, the lag factor's filtering of the change, and the table lookup based on all that allow you to do otherwise.
In my experience this can largely be tuned around on MAP/Alpha-N/ITB-mode cars by getting a stable MAP signal and then getting rid of lag factor. With MAF I can see it being a bigger issue, which would explain why the factories do it.
