MS2 Can output to Arduino
(Runs on MS2 and Microsquirt)
kevin.debosscher
Post by kevin.debosscher »
Hey Dudes!
Been searching for weeks to establish a simple communication between an arduino and MS2.But can't get it to work :/
Anybody that has a basic sketch?
All i want is to read simple data like rpm,clt, etc basic stuff
I want to stay on the 325 firmware sow can request messages comes in iirc?
Or are there other,easier solutions?
Thanks!!
Code: Select all
#include <SPI.h>
#include "mcp_can.h"
//raw readings
int seconds = 0;
int pw1 = 0;
int pw2 = 0;
int rpm = 0;
int adv = 0;
float afrtgt1 = 0.0;
float baro = 0;
float MAP = 0;
float mat = 0;
float clt = 0;
int tps = 0;
float bat = 1;
float afr1 = 1;
int cel_status = 0;
unsigned long previousMillis = 0;
unsigned char Flag_Recv = 0;
unsigned char len = 0;
unsigned char buf[8];
INT32U canId = 0x000;
char str[20];
MCP_CAN CAN(10);                                            // Set CS to pin 10
void setup()
    Serial.begin(115200);
    CAN.begin(CAN_500KBPS);                       // init can bus : baudrate = 500k
    CAN.init_Mask(0,0,0x7ff);
    CAN.init_Mask(1,0,0x7ff);
    //CAN.init_Filt(0,0,0x5f0);
    //CAN.init_Filt(1,0,0x5f2);
    //CAN.init_Filt(2,0,0x5f3);
    //CAN.init_Filt(3,0,0x0);
    //CAN.init_Filt(4,0,0x0);
    //CAN.init_Filt(5,0,0x0);
void loop() {
  canRead();
  //rpmSmoothing();
  canDisplay();
void canRead() {
  if(CAN_MSGAVAIL == CAN.checkReceive()) {         // check if data coming
    CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
    switch (CAN.getCanId()) {
    case 0x5f0:
      seconds = word(buf[0] , buf[1]);
      pw1 = word(buf[2] , buf[3]);
      pw2 = word(buf[4] , buf[5]);
      rpm = word(buf[6] , buf[7]);
      break;
    case 0x5f1:  // Group 1
      adv = word(buf[0] , buf[1]);
      afrtgt1 = buf[4];
      //mat = word(buf[4] , buf[5]);
      //clt = word(buf[6] , buf[7]);
      break;
    case 0x5f2:  // Group 2
      baro = word(buf[0] , buf[1]);
      MAP = word(buf[2] , buf[3]);
      break;
    case 0x5f3:   // Group 3
      tps = ((buf[0] * 256) + buf[1]);
      bat = ((buf[2] * 256) + buf[3]);
      afr1 = ((buf[4] * 256) + buf[5]);
      //afr2 = (((buf[6] *256) + buf[7]);
      break;
void canDisplay() {
  const int interval = 50;
  unsigned long currentMillis = millis();
  //refresh rate
  if (currentMillis - previousMillis >= interval) { //if time elapsed is greater than the signal interval
    previousMillis = currentMillis; //then reset time
    Serial.print(" Snds ");
    Serial.print(seconds);
    Serial.print(" RPM ");
    Serial.print(rpm);
    Serial.print(" PW1 ");
    Serial.print(pw1/1000, 2);
    Serial.print(" ADV ");
    Serial.print(adv/10, 1);
    Serial.print(" AFRtgt ");
    Serial.print(afrtgt1/10, 1);
    Serial.print(" AFR ");
    Serial.print(afr1/10, 1);
    Serial.print(" MAP ");
    Serial.print(MAP/10, 1);
    Serial.print(" CLT ");
    Serial.print(clt/10, 1);
    Serial.print(" TPS ");
    Serial.print(tps/10);
    Serial.println(" ");
Re: MS2 Can output to Arduino
Post by jsmcortina »
I didn't read your code in detail.
Two options.
A. Use the current firmware and enable CAN broadcasting which is simple to receive on third party devices.
B. Implement Megasquirt CAN.
Specifications for both are available on the Manuals page.
winstonusmc
Post by winstonusmc »
Thought this looked familiar when I read your post. Post up some info on your hardware setup, like what CAN shield you are using and how you are plugged into the arduino. I used a cheap chinese CAN transceiver that I had to modify to get it to work.
You need to start off with a simple can receive sketch that allows you to see everything without any type of filter. This will allow you to see the raw traffic without trying to tie it to any variables. Use the examples from the library for the Sparkfun CAN shield, I am pretty sure that is what I used. The receive example is pretty simple.
The sketch you posted up was an evolution of that process. Unfortunately with Ardiuno, there is too many different setups you can have to simply copy someone else's sketch. You need to understand the process within the sketch to adapt it to you own setup. Its kinda like Megasquirt itself in that aspect. Not that I am upset in any way about copying, thats why I post it up, to help people learn.
Nissan Skyline R34 RB26DETT ran MS3/MS3X w/ factory Hitachi CAS (sold)
Nissan Silvia S14 RB25DE ITB/NA ran MS3/MS3X w/ factory Mitsubishi CAS (disassembled)
Datsun 240z RB25DE ITB/NA with MS3/MS3X
kevin.debosscher
Arduino Uno with a MCP2515 shield
MS2 with 325firm
winstonusmc
If you are using an Uno or similar, you may have to change the crystal to 16mhz crystal to get it to work. Just check the crystal on the arduino. The sketch should work just fine then as its the same CAN device I use. It works with my UNO, Mega, and pro mini, all at 16mhz. Just start with the "receive check" example to make sure everything works first.
Alfagta
Post by Alfagta »
I have tested the com to an MS 2 and 3 with this shield and arduino with 20Mhz.
No problem...
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
grom_e30
Post by grom_e30 »
i have the exact same with 8mhz crystal i had to set can bus speed to 1000kbps to get it to work.
Alfagta
Post by Alfagta »
I think the crystal on the shield has nothiung to do with the speed on the arduino.
The crystal on the shield is for the canbus chip.
The arduino talk with spi with the canbus chip. And you can setup a speed for the spi....
I have used µc and the mcp canbus chip with different crystal without any problem.
Some of the arduino lib's for the mcp are not 100% working. I tried some of them. But then i create one myself..
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
grom_e30
Post by grom_e30 »
if i put a 16mhz crystal in the can bus it connects and works if set to 500kbps, with the 8mhz crystal the can speed has to be set to 1000kbps for it to work the exact same ebay china can bus module.
Alfagta
Post by Alfagta »
Maybe the canbus timing registers setup where not correct.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
kevin.debosscher
Just updated to the newer broadcasting firm.
I finaly receive some can data but they are in this format:
Code: Select all
CAN ID: 243
data len = 8
4	119	0	137	0	74	0	74
Now I'm stuck in how to convert to logical values...
What data were you trying to send?
kevin.debosscher
Hello James,
Under CAN realtime data broadcasting:
02:baro,map,mat,clt
These are 11bit?
You need to read the upper byte of the CANid too. (11 bits don't fit into 8 bits !)
Did you read the broadcasting PDF where it explains how the data is laid out?
kevin.debosscher
I've been reading so many things... :RTFM:
Can you post a link with the correct info James?
Really a noob in canbus stuff
Follow the "Manuals" link above and scroll down to the end.
kevin.debosscher
I really don't see it...
Need to sleep!
If somebody spot the error in the codes,:
Code: Select all
#include <SPI.h>
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
char str[20];
INT8U Flag_Recv = 0;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
void setup()
START_INIT:
    if(CAN_OK == CAN.begin(CAN_500KBPS))                   // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init ok!");
    else
        Serial.println("CAN BUS Shield init fail");
        Serial.println("Init CAN BUS Shield again");
        delay(100);
        goto START_INIT;
unsigned char stmp[8] = {0, 1, 2, 3, 4, 5, 6, 7};
void loop()
  // send data:  id = 0x00, stock frame, data len = 8, stmp: data buf
    CAN.sendMsgBuf(0x0c, 0, 8, stmp);
    delay(10);                       // send data per 100ms
      unsigned char canId = CAN.getCanId();
      //Print data to the serial console
      //and the LCD display
      Serial.println("CAN_BUS DATA!");
      Serial.print("CAN ID: ");
      Serial.println(canId);
      Serial.print("data len = ");
      Serial.println(len);
      //This loops through each byte of data and prints it
      for(int i = 0; i<len; i++)    // print the data
          Serial.print(buf[i]);
          Serial.print("\t");
          Serial.println();
          delay(200);
Alfagta
Post by Alfagta »
What are you trying with this code.
You send a Message out on the bus, wait 10ms and then you read a message??
You try to read the message you have sendet?
Are you connected to the MS Canbus?
From which source do you have the mcp lib?
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
kevin.debosscher wrote:I really don't see it...
What don't you see?
- the PDF that describes the CAN protocol?
- the byte packing explanation?
