To announce the release of “MS2/Extra Pre 3.4.2 beta 1” this follows 3.4.1 release
Who should use this code?
Experienced users wanting to test the new features or users experiencing bugs fixed by this version.
Who should not use this code?
New or casual users – please use the current release code instead – see the Downloads page linked above.
Main changes since 3.4.1 release
Bug fixes:
Change 2-cyl calc_divider calc to match MS3.
Mitigate high-RPM sync-loss noise filter lockout and respect HEI bypass.
Block ASE after high-RPM sync-loss.
Changed features:
Remove HE351 CAN broadcast option. (Wrong baud.)
Minor/internal:
Optimise variables to reduce ram usage and free up stack space.
pPTMpin[] as individual variables to save 4 bytes.
#ifdef out user_defined by default.
trig offset tooltip
Add #defines for LOADOPTS_*
Incorporate AFR tooltip.
The zip can be downloaded from:
http://www.msextra.com/downloads/dev/ms ... -4-2beta1/
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
The current TunerStudio (2.6.0 or later) is required.
MS2/Extra pre-3.4.2 beta 1 released
