GM 7X Sequential and COP
Is there any chance sequential fuel injection and COP will be supported when using GM 7X along with the cam input ? I also see improvements in the code for MS3 when running GM 7X, any chance that will get back ported?
Thanks, Huey
Thanks, Huey
Dodge 2.2L MPI Turbo Power Running MSnS1/Extra.
Chevrolet 5.3 LM7 running MSnS2 /Extra
Chevrolet Twin Cam 4 cyl running MSnS2 / Extra
Home of the USB data logger---> http://www.msextra.com/forums/viewtopic ... 67&t=34901
Re: GM 7X Sequential and COP
Just my $0.02 but knowing the timing issues with the GM 7x - your going to need to move to MS3 to get it. The exhaust VVT cam wheel required a dedicated timing routine. This is based on the LL8 4200 engine.
Is the engine your running?
I'm just running a twin cam 4 cylinder on it.
Huey can you run me threw the set up for the ignition , I need to know what settings for the 7x and cop you are using I have a ecotec 2.2
Sent from my iPad using Tapatalk
Could you walk me threw the steps to set up 7x in tuner studio
How about me emailing you the MSQ file so you can review it ? I'm running the 2 original coils as wasted spark and drive them directly with the MS2.Spooledup50 wrote:Could you walk me threw the steps to set up 7x in tuner studio
What MS2 variant?Spooledup50 wrote:Huey can you run me threw the set up for the ignition , I need to know what settings for the 7x and cop you are using I have a ecotec 2.2
Huey,
Would you be willing to post your current MSQ? I'm getting ready to convert a 1.9 DOHC Saturn to MS2/Extra and would really appreciate seeing some known-good settings. I believe this engine uses the 7x signal.
thanks,
-Dave
thanks,
-Dave
Here you go. The lower end of the timing table is set to -10 degrees due to me using a GM HEI module as a VR conditioner. It to looses sync during cranking and the -10 setting keeps it from kicking back so hard. I have the correct hardware and will change it sometime. The engine is a 1998 Chevy Malibu 2.4L LD9 on a rail buggy and runs great. It is running on MS2 Extra pre-3.4.3 beta1.
Huey
Huey
When you say using a GM HEI module as a VR conditioner, are you saying like a 4 pin dizzy application HEI module?Huey wrote:Here you go. The lower end of the timing table is set to -10 degrees due to me using a GM HEI module as a VR conditioner. It to looses sync during cranking and the -10 setting keeps it from kicking back so hard. I have the correct hardware and will change it sometime. The engine is a 1998 Chevy Malibu 2.4L LD9 on a rail buggy and runs great. It is running on MS2 Extra pre-3.4.3 beta1.
Huey
Why wouldn't you use the VR conditioner in the MS?
There should be no reason that it should lose sync during cranking. You either have a hardware set up issue or maybe losing voltage (losing lots) during cranking, but that voltage would need to drop REAL low for that to happen with a GM HEI module.
Tha Daily: 2005 Chevy Blazer
No VR conditioner circuit on the V2.2 PCB. I used what I had available at the time. I will revise it in the future.
Opto only on the V2.2? I've never used one, so I haven't really paid much attention to them.
You still shouldn't be losing sync at start though.
