MS2/Extra pre-3.4.3 beta 1 released
To announce the release of "MS2/Extra Pre 3.4.3 beta 1" this follows "MS2/Extra 3.4.2 release"
Who should use this code?
Experienced users wanting to test the new features or users experiencing bugs fixed by this version. Especially the EDIS bugfix.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since 3.4.2 release
Bug fixes:
Make duty based staging work with 1 squirt simult.
Use correct no_cyl for 36-2-2-2
Changed features:
Minor/internal:
http://www.msextra.com/downloads/dev/ms ... 4-3/beta1/
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
The current TunerStudio (2.6.0 or later) is required.
Bug fixes:
Changed features:
Minor/internal:
Re: MS2/Extra pre-3.4.3 beta 1 released
James, i get strange bug on 3.4.2 with sequential mod and using camshaft sensor.
Later i post my msq.
For example, we have 4cyl, 4 inj, 4 cop. crank 60-2 and cam poll level. All fine, but when we use autotune via TS or push burn button - get many lost syncs untill release clutch or throttle. Reflash didnt helped. But sometimes can help.
Is this specific to this pre-3.4.3 beta 1 ?
Didnt tested yet. Only 3.4.2jsmcortina wrote:Is this specific to this pre-3.4.3 beta 1 ?
Many sync errors when use autotune. Or if you just make some changes and press BURN i get many errors untill release clutch pedal and rpm down to idle.
So why are you posting to a topic about pre-3.4.3 beta 1?acab wrote:Didnt tested yet. Only 3.4.2.jsmcortina wrote:Is this specific to this pre-3.4.3 beta 1 ?
Hello James,
i have a question according to the boost control.
Initial situation i have boost closed loop active with basic tuning mode.
So when the map reach the target - delta region boost ctl starts working.
When we are in closed loop for the first ms loop i thinkt there is something wrong with the calculation of the duty.
Within the first loop error and last error is set to the same value. Therefore Kp is 0.
Ki is something arround 5500.
Kd is something arround 134277.
So because of this values the setpoint is negative an nailed to the min duty.
Can you have a look into this please?
Correct me if i'm wrong.
BR
BR
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfagta wrote:Hello James,
Is this specific to this beta?
Yes it is.
Take a look into boost_ctl
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
I checked the code and nothing has really changed in boost_ctl for about three years, so I don't see how this can be specific to this beta.
Oh, so then it's not only specific to this beta, its a global thing.
I think it's not important if it's thgis beta or all versions. When they have all the same code you can check in any off them.
I will figure out why always when closed loop boost starts there is a spyke in the boost duty to the min allowed valve value.
BR
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
It does matter for developers to know if this is a new issue or a long-standing one - otherwise we go looking for recent changes rather than the code in general.
Okay so now you know to llok into the code itself.
BR
BR
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
James, please, check thaе msq, we burn two engines becouse REV LIMIT didnt work
That problem affect to 3.4.2 and last beta.
I tested and no fault found. It works correctly.acab wrote:James, please, check thaе msq, we burn two engines becouse REV LIMIT didnt work
James, can you check, 36-2-2-2 on EJ30 with 6 COP or wasted spark will work fine?
Has something changed in this beta?
I just see that ;(jsmcortina wrote:Has something changed in this beta?
jsmcortina wrote:It does matter for developers to know if this is a new issue or a long-standing one - otherwise we go looking for recent changes rather than the code in general.
Hello James,
have you ever tried to calculate the behavior with the first loop in the cl boost fucntion on a white paper?
Best regards
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
