Request: TachOutput scaling factor
As stated in the title, a scaling for the tacho output would be nice, if it could be done easily. I guess most tachometers display a little too much, but with the bike I have, it's about +6.5% - very annoying in the upper revs near the limiter.
I think a simple adjustable scaling factor would do the trick.
My project: Link
Re: Request: TachOutput scaling factor
not sure its going to happen its been asked for in ms2 in the past, it is in the current ms3 firmware though.
grom_e30 wrote:not sure its going to happen its been asked for in ms2 in the past, it is in the current ms3 firmware though.
Where can this be found in the MS3 firmware (TS interface) to adjust it?
Tha Daily: 2005 Chevy Blazer
On an ms3 tune it's under tacho output under the basic/load tab
I only see normal and half speed, no scaling factor, on both MS3 and MS3Pro...
Update to a newer MS3 Firmware.
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
download the current firmware 1.4.1 from the downloads page and there is a fixed or variable option in there
I see that in the new MS3 firmware, which is cool, but that doesn't help anyone, like the OP, that is running an MS2. ;)
Upsell feature set
Not everyone wants, nor can run an MS3...
I believe the MS3 tach output scaling feature is driven off a hardware timer, and I'm not sure the MS2 has any timers free. I only took a cursory look at the code myself, but it seems this is probably a feature that hasn't been brought over due to hardware limitations. You could, however, use one of these if you don't have the budget for an MS3 daughter card.
Yes, that's pretty normal isn't it?nathaninwa wrote:Upsell feature set
So what's your point?Six_Shooter wrote:Not everyone wants, nor can run an MS3...
The guy who wants a stock Corolla that can do 0-60 in 3-1/2 seconds is out of luck too. If you want 0-60 in 3-1/2 seconds, buy a Ferrari. If you want tach scaling, buy an MS3.
On a less cynical note, the reality is the MS2 processor is much less capable than the one in the MS3... that's why the MS3 was designed. It's not reasonable to expect the MS2 processor to do all the same things the MS3 does.
Eric Law
OP here again. Just wanted to let you know I didn't know this was a hardware limitation, and therefore I thought this would have been a few lines of code to add. Sorry to see this seems to have sparked some sort of hostility.
For me personally, this isn't a problem anymore as I built a dashboard using a cheap tablet running MSDroid -> https://www.youtube.com/watch?v=iXBfvSa4UfY , so I'll unsubscribe to this thread.
Thanks anyway, especially to Matt.
My project: Link
Yeah I'm sorry if I came on a little strongly in my other post.
There seems to be a frequent theme here of people thinking every time a feature is released for the MS3 that it will be (or can be) added to MS2 also. If the MS2 was capable of all that, they wouldn't have built the MS3!
The tach scaling in particular is a tricky one. I'm not sure this is how it's done but to implement the MS2 setup, all you'd need to do is watch the trigger signal, and pulse the tach output either each time the trigger fires or every other time. To do scaling like MS3 does where it supports more than just a "x1 or x1/2" relationship between input and output, you need to set up a hardware pulse generator for the output, then constantly monitor the frequency of the input, compute the correct frequency for the output, and set the output pulse generator to that frequency. That's much more difficult and resource-intensive.
Eric Law
