Spark outputs (MS2 development/coding for dummies)
(Runs on MS2 and Microsquirt)
acab
Post by acab »
i found that on code and i want find 2 pins for ignition of that, can anybody help?
Code: Select all
#define COILABIT 0x1
#define COILBBIT 0x2
#define COILCBIT 0x4
#define COILDBIT 0x8
#define COILEBIT 0x10
#define COILFBIT 0x20
#define COILGBIT 0x40 // no outputs connected
#define COILHBIT 0x80 // no outputs connected
Code: Select all
} else if (*coil == TRIGG) {
            if (num_spk == 1) {
                *bits |= COILABIT;
            } else if (num_spk == 2) {
                *bits |= COILABIT;
            } else if (num_spk == 4) {
                *bits |= COILCBIT;
            } else {
                *bits |= COILGBIT;
        } else if (*coil == TRIGH) {
            if (num_spk == 1) {
                *bits |= COILABIT;
                *bits |= COILBBIT;
                *bits |= COILDBIT;
            } else {
                *bits |= COILHBIT;
Re: MS2 development/coding for dummies
Post by jsmcortina »
acab wrote:i found that on code and i want find 2 pins for ignition of that, can anybody help?
Not sure what you are trying to do there?
acab
Post by acab »
jsmcortina wrote: Not sure what you are trying to do there?
connect IAC1 and IAC2 for SPK_G and SPK_H :D
Re: Spark outputs (MS2 development/coding for dummies)
You are on your own there. No idea if the rest of the code supports that as it was only planned to support 6 spark outputs.
