For a single cylinder engine, I guess a better term would be timed injection since what happens is that you can control the injection timing of the single injection pulse. This can have a significant impact on some engines under some conditions.robs wrote:I can't even think what a "single 4-stroke in sequential mode" means. Sequence of one doesn't sound very hard! Anyhow, I'm not certain about sequential injection. I think it'll do something if this option is selected, but the decision process in the code leading up to it is fairly convoluted and it doesn't take much to confuse me.
And the sequential injection code is indeed convoluted but it does not have any impact on the pulse width computations. It just uses the pulse width to determine when the injection should start. Part of the complexity of the code comes from the need to deal with many corner cases such as collisions between successive pulses when the injection start goes back and forth across a tooth trigger. And it is also convoluted due to how it evolved from the initial way I implemented it and the desire and need to use common aspects with the rest of the code and the ignition timing code.
