MS2/Extra pre-3.4.3 beta 2 released
To announce the release of "MS2/Extra Pre 3.4.3 beta 1" this follows "MS2/Extra 3.4.2 release"
Who should use this code?
Experienced users wanting to test the new features or users experiencing bugs fixed by this version. Especially the EDIS bugfix.
Who should not use this code?
New or casual users - please use the current release code instead - see the Downloads page linked above.
Main changes since 3.4.2 release
Bug fixes:
Fix test mode dwell calc for main and trailing spark outputs.
Boost target is kPa not %.
Fix '=' condition in on/off outputs (ancient bug)
Remove erroneous check for boost pins vs. seq inj.
Back-port low RPM dwell overflow fix from MS3.
Changed features:
AFRtarget uses target table even if no sensors configured.
Add "No correction" EGO option.
Minor/internal:
oddfireang decimal
http://www.msextra.com/downloads/dev/ms ... -3/beta-2/
Be sure to read the RELEASE-NOTES.txt and README.txt. Especially note that "Not Synced" has been renamed to "Not RPM synced".
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
The current TunerStudio (2.6.0 or later) is required.
Bug fixes:
Changed features:
Minor/internal:
oddfireang decimal
Re: MS2/Extra pre-3.4.3 beta 2 released
I might have found a bug.
Ignititor number 5 (JS5) is triggered and going high for a very short moment when the Megasquirt is powered on.
This is on a 6 cilinder COP setup.
Same circuit on other outputs, outputs stay low.
It makes the coil spark once, causing a potential backfire on startup if any fuel is in the intake manifold and the intake valve of that cilinder is open.
When I switch the ECU back to 4 cilinders on the stim, I do not see an innitial power-up blimps on any of the ignition outputs. And therefore also not on JS4 and JS5.
I also found this on the release 3.4.2.
I get an configuration error on the 36-2-2-2 Subaru mode.
Number of teeth / cylinders conflict.
Unable to make datalog as ECU locks up.
Tried 4 and 6 cylinders in wasted spark mode. No show.
I have to add 30 degrees to the ignition table to get the ignition timing right and I have the offset maxed out at 20. So tooth no1 angle seems to be 50 degrees off.
Also I get an eratic RPM signal. it bounces ~100rpm This can be seen on the stim. No sync loss.
The MSQ you posted shows "coil on plug" which is not supported and correctly gives a config error.MegaHelp wrote:I get an configuration error on the 36-2-2-2 Subaru mode.
Setting to "wasted spark" gets rid of the config error.
It is possible that nobody has ever tested this since it was added ten years ago.MegaHelp wrote:I have a problem with the Rover #3 trigger under 3.4.2. Tried it on 3.4.3B2, same problem.
Please start a new topic, detail the engine and post a composite log taken using "Log crank" ignition mode.
I could.
However, Jean's Stimulator is giving the correct output. So you could easily see what is going wrong on the input thing.
It is mentioned in his documentation as Rover 36-2-2. All dipswitches down, 2,5 and 6 up. In Tunerstudio it is Rover #3.
I'll check the actual MSQ on the car to determine how far the tooth#1 angle is off.
What about the Subaru 36-2-2-2 ?
