True Flex Fuel Support
(Runs on MS2 and Microsquirt)
Postby Jazracing » Fri Dec 02, 2016 12:00 am
Is there a reason that flex fuel on MS2 isn't set up to interpolate between two sets of Fuel, AFR, and spark maps? Is this a hardware limitation?
Jazracing
Re: True Flex Fuel Support
Postby jsmcortina » Fri Dec 02, 2016 3:16 am
For more Flex and blending options, upgrade to MS3.
Postby Matt Cramer » Fri Dec 02, 2016 7:47 am
The MS3 doesn't just blend between fuel, spark, and AFR tables, either - it also blends between separate cranking, AE, warmup, and other settings. The MS2 doesn't really have enough processing power to pull this off.
Postby amd is the best » Fri Jul 28, 2017 4:08 am
I'd love a more advanced flex fuel control for my MicroSquirt as well. Upgrading to MS3 on my motorcycle isn't really an option as I need the small form factor as well as the water resistance.
amd is the best
Postby grom_e30 » Fri Jul 28, 2017 4:49 am
how about the ms3 pro range
grom_e30
