True Flex Fuel Support
(Runs on MS2 and Microsquirt)
Jazracing
Post by Jazracing »
Is there a reason that flex fuel on MS2 isn't set up to interpolate between two sets of Fuel, AFR, and spark maps? Is this a hardware limitation?
Re: True Flex Fuel Support
For more Flex and blending options, upgrade to MS3.
The MS3 doesn't just blend between fuel, spark, and AFR tables, either - it also blends between separate cranking, AE, warmup, and other settings. The MS2 doesn't really have enough processing power to pull this off.
amd is the best
Post by amd is the best »
I'd love a more advanced flex fuel control for my MicroSquirt as well. Upgrading to MS3 on my motorcycle isn't really an option as I need the small form factor as well as the water resistance.
grom_e30
Post by grom_e30 »
how about the ms3 pro range
