I've noticed on a SBFord with a converted carb to efi intake that the outer 4 holes (1,5,4,8) run richer than the inner 4 (2,3,6,7). I assume this happens while idling and under boost. I also happen to have my 2 channels wired with outer 4 to channel 1 and inner 4 to channel 2.
I've thought about dual table but keeping the 2 sorted seems a bit of a pain when % gives better resolution.
Any thoughts, opinions...
VE trims in untimed mode
