untimed batch fire vetrim tables
(Runs on MS2 and Microsquirt)
Postby ol boy » Sat Jul 01, 2017 9:32 am
What's needed to enable the fuel injector ve trim tables? On my V8 Ford the outer 4 holes run richer than the inner 4 holes. I have channel 1 wired to 1,4,5,8 and 2,3,7,6 to channel 2. Ive sorted a work around by setting the ecu to simi-sequential and only use 2 channels. The require fuel value ends up quite small but it's working. Just wondering what's needed to enable trims when only using 2 fuel channels.
Thanks Ryan
306 SBFord, Torquer II EFI intake, 60 lbs injectors, 8 LS2 coils, VS Racing 7668 turbo, 4R70W, MS2extra 3.4.x_ish
ol boy
Re: untimed batch fire vetrim tables
Postby Blown88GT » Tue Jul 18, 2017 4:53 pm
1988 Mustang GT, 57k miles, Orig. Owner
ProCharger 600B I/C, 12psi, FRPP Hdrs, Flwmstr F2, 3G Alt, Mk8 Fan & DCC, 3.55's, Prog Sprng, Subfrms, UCA, LCA, FCA, Tokico 5-way, CSA 16x8, Bridgestone RE760 225/50R16, Crane HI-6, Kirban FPR, MS2, DIYPNPF60, LC2, C&L76mm blo-thru MAF, 30lb FRPP
Blown88GT
Postby ol boy » Tue Jul 25, 2017 10:07 pm
So just what i did then. Switching to simi-sequential really messes with the required fuel value to get it running right. Would be nice to have untimed with channel trims.
ol boy
