IAC output/s to control 3-Wire Idle Valve?
(Runs on MS2 and Microsquirt)
phoenix3d
Post by phoenix3d »
Would it be Possible to run 3-wire Idle valve on one of the IAC Outputs. ( I know it's not currently supported)
But would it be feasible, As the H-Bridge is by norm a sort of Push-Pull set up? (ie. IAC1A <- Power -> IAC1B)
I would love to try but unfortunately the Option for IAC1 or 2 is not available under Fidle PWM output.
Please, if I am totally farting in the wind let me know... and why... :D
Kindest Regards
Gordon.
Re: IAC output/s to control 3-Wire Idle Valve?
I'm pretty sure that the current capacity of the H-bridge driver is too low for typical PWM valves.
juansh2385
Post by juansh2385 »
James If we drive 2 tip120 from one iac output and its complementary pin it should work.
Vicoor
Post by Vicoor »
If you search you can find schematics for a circuit to drive a "traditional" 3 wire PWM IACV.
However make sure that's the kind of valve you have. There are many 2000 and newer cars that have a 3 wire connector but it is power ground and a 5V digital PWM that does the controlling.
I posted about this before
http://www.msextra.com/forums/viewtopic.php?t=64781
Don't Talk About it,,,Just Do It!
1993 Toyota P/U 22RE V3.0 MS2/Extra 3.4.2 Full sequential Injection & Spark
